Questioning if the CL-S should get the boot (comparo to 08 Accord)
Hopefully I’m not the only one here...I love my CL-S but thoughts have crossed my mind of maybe trading in the CL-S for something still practicle but maybe a little newer. My first thought was the new Accord I researched a little and this is some of the info I found. I thought this was kinda of a good comparo list of the 01 CL-S and the 08 Accord Coupe /Sedan. On paper they are not that different. Esp. with emphasis on mpg (which the 08 accord has cylinder deactivation), 0-60 & quarter mile (even though MT estimated it’s still close) I know it’s mag racing at its best but just wanted to share a side by side comparison on paper. Both this info was taken from MT. Just my
but for the money I'm saving, I'm damn happy with 01 CL-S and my pocket is too. After looking at what is out there I can’t justify spending that much money for a car that is pretty much the same thing (even though the new accords might be slightly faster..but who cares if I wanted a fast car I would have bought a rwd sports car)..Especially since my car is paid off and it's in perfect condition. Looks like I'll be keeping the CL-S until it doesn't run anymore... End Rant
Hope you all enjoy
2001 Acura CL-S
POWERTRAIN/CHASSIS
Drivetrain layout Front-engine, fwd
Engine type V-6, SOHC, 4 valves/cyl, aluminum block and heads
Displacement, ci/cc 195.9/3210
Hp @ rpm 260 @ 6100
Torque @ rpm 232 @ 3500
Transmission 5-speed automatic
Suspension, front; rear Upper and lower control arms, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
Brakes, front; rear 11.8-in vented disc; 11.1-in disc, ABS
Wheels 17x7.0 cast aluminum
Tires 215/50R17 93V Michelin MXM4
Traction control Yes
DIMENSIONS
Wheelbase, in 106.9
Length, in 192.0
Width, in 69.2
Height, in 53.3
Curb weight, lb 3510
Seating capacity 5
Cargo capacity, cu ft 13.6
Fuel capacity, gal 17.2
TEST DATA
0-60 mph, sec 6.4
1/4 mile, sec @ mph 14.8 @ 96.5 Braking, 60-0 mph, ft 124
600-ft slalom, mph 63.7
Total mileage 9475
Avg test mpg 23.6
Problem areas Airbag sensor, creaking sunroof
Non-warr cost $0.00
CONSUMER INFO
Base price $30,300
Price as tested $32,810
Airbags Dual front, front-side
EPA mpg, city/hwy 19/29
Range, city/hwy, miles 327/499
Basic warranty 4 yrs/50,000 miles
Powertrain warranty 4 yrs/50,000 miles
Roadside assistance 4 yrs/50,000 miles
Recalls None
2008 Honda Accord EX-L V-6
Drivetrain layout Front engine, FWD
Engine type 60-deg V-6 alum block/heads
Valvetrain SOHC 4 valves/cyl
Displacement 211.8 cu in/3471 cc
Compression ratio 10.5:1
Power (SAE net) 268 hp @ 6000~6200 rpm
Torque (SAE net) 248 lb-ft @ 5000 rpm
Redline 6800 rpm
Weight to Power 13.2 lb/hp
Axle/final-drive ratios 4.31/2.64
Suspension, front; rear Control arms, coil springs, anti-roll bar;
Steering ratio 13.1:1
Turns lock-to-lock 2.6
Brakes, f;r 11.8-in vented disc; 11.1-in disc, ABS
Wheels 7.5 x 17 in, cast aluminum
Tires 225/50R17 93V Michelin Pilot HX MXM4
Wheelbase 110.2
Track, f;r 62.2/62.2
Length x width x height 194.3 x 72.7 x 58.1 in
Turning circle 37.0 ft
Curb weight 3519 lb
Weight dist, f/r 62/38%
Seating capacity 5
Headroom, f/r 39.0/37.2 in
Legroom, f/r 42.5/37.2 in
Shoulder room, f/r 58.2/56.4 in
Cargo volume 14.0 cu ft
TEST DATA
Acceleration to mph
0-60 6.5 sec (est)
Quarter mile 14.8 sec @ 95.0 mph (est)
CONSUMER INFO
Base Price $28,000 (est)
Price As Tested $30,000 (est)
Stability/traction control Yes/yes
Airbags Dual front, front side, f/r curtain
Basic warranty 3 yrs/36,000 miles
Powertrain warranty 5 yrs/60,000 miles
Roadside assistance N/A
Fuel capacity 18.5 gal
EPA city/hwy econ 19/29 mpg
CO2 emissions 0.86 lb/mile
Hope you all enjoy
2001 Acura CL-S
POWERTRAIN/CHASSIS
Hp @ rpm 260 @ 6100
DIMENSIONS
Wheelbase, in 106.9
Length, in 192.0
Width, in 69.2
Height, in 53.3
Seating capacity 5
TEST DATA
0-60 mph, sec 6.4
Total mileage 9475
Avg test mpg 23.6
Non-warr cost $0.00
CONSUMER INFO
Base price $30,300
Recalls None
Redline 6800 rpm
Wheelbase 110.2
Curb weight 3519 lb
Seating capacity 5
TEST DATA
Acceleration to mph
0-60 6.5 sec (est)
CONSUMER INFO
Don't Mess With Texas
the GF just picked up a blk/blk nav EX-L coupe a couple weeks ago. i'll see if i can get some pics today if we washed it.
i think some of that info you posted about the accord might be wrong. if im not mistaken i think hers has 18 inch wheels.
seating in the CL is also rated at 4.
thats just what caught my eye in skimming the info.
hope these new accords dont have the same brake issues the CL's have been plauged with.
The Accord coupe 6mt is pretty much the replacement for the CLS in the Honda/Acura lineup, so it makes sense that alot of people here would like it...
I always thought of the 7th Gen Accord as the 3rd Gen CL, so I guess an 08 accord would be a 4th gen CL![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Hmmm... maybe H/A should just let honda sell the sedan, and market the coupe as an acura...
eh
The V6 Accord Coupe comes with 235/45/R18s.... you have the tire specs for the 4 cyl.
And I'm betting the manual will do low 14s in the 1/4 mile no prob.
But yeah ... its still not much of an upgrade. I've also heard from people that have made the switch that they found the build quality a little better in the CL - less sqeaks and rattles.
Plus I'd rather own an Acura than a Honda - I don't care if that's petty
To all yea I noticed some of Motor Trends info was a little off. This info was from a 08 Accord Sedan. I probably should have grabbed the Coupe info but couldn't find it on MT at least. This was just suppose to be a general comparo so don't read into it too much
Yea I drove my neighbors 08 sedan (V6) today and damn its a nice car...a bit too soft of a ride for me (I have tanabe suspension on my 01 Cl-s) and d*mn thats a huge car. It felt so much bigger and taller than my car (see specs below) but its a damn powerful fwd car. I could def. feel more the more tq in her car. I didn't get to take it on the open road so I am not too sure how much more powerful it is on the open road. Maybe some time in the future. But I too have heard of the quality in the Acura's is slightly better. Once again I was impressed by the Accord today...but not enough to trade in just yet. I still feel my Cl-s is just as good all around.
2001 CL-S
Wheelbase, in 106.9
Length, in 192.0
Width, in 69.2
Height, in 53.3
08 Accord Sedan
Wheelbase 110.2
2001 CL-S
Wheelbase, in 106.9
Length, in 192.0
Width, in 69.2
Height, in 53.3
08 Accord Sedan
Wheelbase 110.2
Hey, I think you should get the Accord. Also, don't trade in your CL, give it as a gift to me, that way I can have a coupe to go with my sedan haha. Seriously though, the CL is a sporty looking car, while to me the new Accord does not. Now the 03-05 Accord coupe is gorgeous, I'd take that any day over the CL-S.
Your mom is in
yeaa i noticed the similarities when the '08 accord first came out too, and im not even being biased when i say that i still feel like my CLS is better, it just is, insurance is cheaper obviously cause its older, its still in great condition, i love my HID's, its an acura, etc, and hell it still looks really good, i mean i only have like 76k miles on it, so it hasnt even started to "feel" old , ill wait at least another year or two to buy another car...i want an s2k soo bad...
Originally Posted by CleanCL
the accord is a family sedan and that's all it should ever be.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally Posted by TOPHER33884
Agree with everyone, the 08 accords are nice.....im also partial to the 08' G37x by infinity & the 08' 350Z too.
unless your all about the speed factor of course...
Originally Posted by cltypeSLOW
Those are some tight pics. Hands down best pics I've seen of any new accord. Black looks great! I've been contemplating and I have finally come to the realization even though the new accord is a nice car...I can't downgrade from Acura to Honda(even though the new accord is faster and maybe better tech) I just feel my 01 Acura is still a notch better and it would be stupid to sell the CL...esp. for the new accords price tag. By no means I am not defending anybody else to keep/sell their CL for a new Accord but this is just the way I feel and I just hope in the next couple years Acura steps up and comes out with a rwd/awd sport coupe.
I just hope they don't try uping the hp on a fwd car...kinda pointless to me. my
In the Mid-South meow
Plus I'd rather own an Acura than a Honda - I don't care if that's petty![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
And according the the mags (I know, mag #s but...) the new 6mt runs a 14.5 in the 1/4 mile, the same as the 7th Gen. Blame that one on the significant weight gain.
Originally Posted by AcUrAge703
Exactly what i think...why move from a cls to an accord...yea its nice but i rather stay within the luxury class...with out having to buy every option available to you...
URL Not Found!
I got 109k Miles on my 01 CLS and it's running SMOOOOTH *knock on wood*...
when it dies... i'm hoping to get to 200k.....i'll pick up a camry hybrid...my dad has a 99 avalon xls with over 250k miles on it and it runs like BRAND new!!
gotta love the hondas/acuras/toyotas of the world!
ya I like the new accord. everyone already knows its damn near the CLS remodeled and with a H badge (bodystyle wise primarily of course) but I still love the front end of my car a whole lot. personally, I wouldnt do it but whatever blows your hair back man, go for it. =)
