Q's for those with Rotora BBK
Old Oct 6, 2005 | 01:06 PM
Chr8808's Avatar
-What other choices in brake pads do we have? I havent installed mine yet but im just curious how limited our choices are.
- As for spacers with the stock wheels. I read that we are supposed to get the 5MM with the 64MM something spacing (H-R), the spacers i got were 5MM with 70MM, how will this affect the ride? will this cause vibrations or throw the balance off?
- Was there an install/spec manual that came with it? If so, is this available thru rotora? (i didnt see it on their site)
- Are there any special install tips? anything out of the ordinary? I've heard we have to remove the dust shield?
Old Oct 6, 2005 | 01:17 PM
Smitty's Avatar
You can get ceramic pads, but they are recommended for off-road use only.
The sparer should be okay.. I have some 5MM/64 if you need 4 of them.
Specs should of came will all your paperwork.
Install tips?.. nah, pretty straight forward, make sure you have a torque screw driver to get the rotor screws off. (I have about 2 dozen new screws if you need some of them too)
the dust shield needs removed.. I used tin snips after I removed the 2 screws out of the rear of the shield.
drillzzz
Jul 28, 2019 06:30 PM
Jul 16, 2017 07:33 AM
yesSIR-S
May 13, 2016 05:42 PM
handsom-hustla
Nov 13, 2015 05:04 PM
