Pulling Left CL-S
5th Gear
Pulling Left CL-S
A quick question.. I have an '03 CL-S, 6 speed. Bone stock with 4K miles on it. I have noticed that it wants to drift left. The tendency is slight, but it is there. I originally thought it was an alignment issue, but recently realized that it only happens under power. In other words, it tracks perfectly straight if coasting in Neutral.
Is this a design issue inherent with the CL-6 speeds?
Any help would be appreciated.
Tom
Tom
5th Gear
Pulling Left
Thanks for the reply...
I realize what it is, but I have never owned a car that could not track straight on the highway (at steady speedy) due to torque steer. Are you saying that this is normal for all CL-S-6's? I would expect this under heavy acceleration, but not in constant speed situations.
5th Gear
No.. and it has been like this from day 1. I just called the dealer and he said that people have mentioned torque steer under acceleration, but not on the highway like I am noting. He's going to take a look at the alignment, so we'll see what he comes up with. I do not expect him to find an alignment problem (since it track perfect while not in gear), but we'll see.
Re: Pulling Left
Black is a ***** to Clean
1 Post
Originally posted by blackcoupe
Interesting enough, my CL seems to pull to the Right a bit. I never thought about FWD torque steer. Is there anything to that can be done about it?
Another related issue is that if you are slowing down to a stop (ex. 30mph to 0mph) while centering steering wheel and then letting go of it....by around 10mph, the steering wheel turns on is on about 30 degrees to the right. I almost always have to have both hands on the wheel when I stop.
If the wheel is slightly turned during acceleration you can feel the HLSD working and potentially pulling into the turn some. If it is present in a single direction regardless of wheel angle including straight it is something else and you may want to look into it.
The torque steer on this car is minimal to non-existent. I was testing this the other day and even with the supercharger at full steam and wheels hopping I was tracking straight when I started straight.
Spectacular Aroma About
yeah,yeah,uh,huh,wh,what
Re: Pulling Left CL-S
Tom
Tom
SidhuSaaB
05-30-2020 12:40 AM
ripit
09-26-2015 06:19 PM
