The pulley is here
Old Nov 23, 2009 | 11:57 PM
madmuzik09's Avatar
Waits for Shakira in his
The pulley is here
the pulley is here and CL progression your right just holding it feels good
pic
Old Nov 24, 2009 | 01:14 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
that's worth more $ in raw materials (aluminum) than it cost as a pulley. If you think about it it's amazing really.
I was stunned when I got mine. to think ppl will pay 10xs for absolutely nothing is funny really.
you will not be disappointed
Old Nov 24, 2009 | 01:20 AM
MrFluffy's Avatar
To many cars in my garage
Is it just a light weight pully or is it smaller ie. do have to change the belt too
Old Nov 24, 2009 | 01:51 AM
brian6speed's Avatar
Lone Wolf
If its the one i just bought, which i think it is it is Options underdrive pulley. You need to get new belts. I got Gates belts K040425 and K060441.
Old Nov 24, 2009 | 04:19 AM
Rajca's Avatar
wham bam thank you ma'am
only thing is, that the oe size ur light weight pulley is lighter than the underdrive. i got both and gonna put the underdrive pulley on this weekend
Old Nov 24, 2009 | 06:44 AM
madmuzik09's Avatar
ill get the belt this friday then put it on same day
Old Nov 24, 2009 | 07:09 AM
StreetKA's Avatar
quick question and i am looking for quick answer. what size of socket do i need to get crank pulley
Old Nov 24, 2009 | 08:12 AM
19mm
Old Nov 24, 2009 | 08:13 AM
i'm pretty sure... but I could b wrong...
get a 19mm and see if she fits quick time.
get a really strong one, or u'll break the socket like it's wood. lol
Old Nov 24, 2009 | 09:06 AM
womey's Avatar
Not 4 Wheelin Anymore!
This may be a dumb question, but how do you torque the crank pulley back down when re-installing since the engine will turn? Did you have someone stand on the brakes in gear?
Old Nov 24, 2009 | 04:18 PM
friesm2000's Avatar
B A N N E D
ummm..... impact or have some one else pry against the flywheel while you torque the bolt
Old Nov 24, 2009 | 05:10 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
impact is key,on and off
Old Dec 30, 2009 | 05:46 PM
StreetKA's Avatar
you are so damn wrong brake bar had to be used and i did it today its a such a big difference i left in love with my car again
Old Dec 30, 2009 | 06:46 PM
Rapture's Avatar
Getting my pulley put in tomorrow. I went to an auto parts store (the only one around me that doesn't have dumbass clerks) and the only belts they had were the Gates, not the Gatorbacks. And of course it was only ONE of the two belts, on top of that. I had to order the other belt online. Funny thing about that is that I bought the belt on Amazon.com, and the belt + one day shipping cost about as much as the other belt I picked up at the store...
Old Dec 30, 2009 | 06:49 PM
StreetKA's Avatar
my friend told me that gates belts are better than gatorback idk what to say...
Old Dec 30, 2009 | 08:12 PM
Rapture's Avatar
Yeah all the other Option pulley DIYs I've seen all say to use the Gates. But then a lot of people here insist "Don't use Gates, get Gatorbacks"
I hear the Gatorbacks have a different kind of rib to them on the underside. Makes less noise? I dunno...
Old Dec 30, 2009 | 08:16 PM
Rajca's Avatar
for me, as long as it works. and i got gatorbacks
Old Dec 30, 2009 | 09:07 PM
StreetKA's Avatar
same here
Old Dec 30, 2009 | 10:16 PM
friesm2000's Avatar
B A N N E D
i would proably prefer the gates one, if they were available, but the gatorbacks will work too
Old Dec 31, 2009 | 11:01 AM
i rock the gatorbacks... they are super silent. never slip... only good things to say.
and yes they have a patented rib design which is consistently offset so there are no lines or ribs, thus the surface contact is consistent and cut out the noise and reduces slippage to ZERO
Old Dec 31, 2009 | 12:47 PM
Rapture's Avatar
Slippage is mostly just a noise issue, like there's nothing mechanical going wrong, is there?
Old Dec 31, 2009 | 01:21 PM
friesm2000's Avatar
B A N N E D
slippage is normally from not being tightened properly, or a weak tensioner spring
or it could also have something on the belt too, or just plain old age with the belt being dryed out
yes slipping is mainly a noise issue, but if it slips enough, it could not spin the alternater enough which would not charge the battery, but we are talking MAJOR slippage there
also make sure the slippage is not caused by one of the accesories seizing up or anything
Old Dec 31, 2009 | 01:26 PM
StreetKA's Avatar
THIS IS A GREAT MOD car feels like it was 400lbs lighter lol revs like crazy... rev matching while shifting gears is so much easier and so much fun
Old Dec 31, 2009 | 03:58 PM
Rapture's Avatar
Yeah I got my pulley put in a little bit ago. My biggest fear was that the guy wouldn't know what he was looking at, but he recognized right off the bat. It seems he had a helluva time getting that bolt off, though.
btw weird thing is that when he was done, I drove on out, but I could hear this faint noise, like a wobbling, or something was moving....? It comes from the driver's side, and it goes away or becomes inaudible by the time I'm in 2nd gear... I don't think it was something he fucked up, considering those two things, but have you guys ever noticed it after you put yours in?
I mean I showed it to him and he wasn't sure either. He said he'd look up to see what it could be. Like I said it seems to come from the driver's side... maybe a side effect from one of the components being underdriven? Or maybe (ugh..) my trans is making the noise...?
Old Dec 31, 2009 | 04:03 PM
Rajca's Avatar
not a side effect. how did he get the bolt off? impact gun? starter method? r u 6spd? did he jam something in the flywheel to stop it from spinning?
friesm2000's Avatar
B A N N E D
if it is the trans making noise, you are just being more sensitive to new noises cause your car was just worked on
Old Dec 31, 2009 | 04:09 PM
Rapture's Avatar
I'm almost positive he used an impact gun. I heard him in there really reefing on the thing, then he had to come in and ask another guy to help him (lol?) and yeah, I'm 5AT
and friesm2000, I'm sure that's probably what's going on. I know I did just that when I put in my CAI
At the very least I'll just keep an eye on it. btw that factory pulley IS pretty damn heavy...
Old Dec 31, 2009 | 07:56 PM
omg so fucking heavy... and that lightens the entire crank imaging how happy the motor is
Old Dec 31, 2009 | 08:00 PM
Rajca's Avatar
^and ur wallet by saving on gas in the long run
Old Dec 31, 2009 | 08:15 PM
Rapture's Avatar
Yeah I dunno what I'll do next to my car. I'm overdue for tinted windows, so I might do that in the spring. That's if I don't get a set of 18" chrome Servos first Just waiting on my year-end bonus.
Old Dec 31, 2009 | 08:16 PM
Rajca's Avatar
what about headers? what have u done to ur car now?
Old Dec 31, 2009 | 08:22 PM
Rapture's Avatar
I dunno the first thing about headers, what all it does exactly, what I'll need to have it installed, etc. In fact I think for the time being my next one will have to be tb spacer, intake manifold gasket, tb gaskets deal. Thinking of getting this next:
http://store.excelerateperformance.c.../i-237040.aspx
Old Dec 31, 2009 | 08:25 PM
Rajca's Avatar
read up on headers. if u love ur pulley. the header is twice as good. any where from 20-30whp, some ppl have seen more.
i got that too, look into the mdx intake manifold spacer. i did a diy on it. but u will need to pop the hood a bit if ur type s
Old Dec 31, 2009 | 10:18 PM
but there are clearance issues man, fuck that bullox
Old Dec 31, 2009 | 10:47 PM
Rajca's Avatar
^true. their are things u can do to get around it
Old Dec 31, 2009 | 11:08 PM
but that's for diehard modders tho bro
Old Dec 31, 2009 | 11:14 PM
i wanna do that mod to my moms mdx for power yo how much do u get on the mdx with that?
Rajca's Avatar
not really. some things to do to get around poping the hood, mill it down, use the 09 tl intake manifold (should clear, well almost positive it will), put a 1/2" shim between teh subframe and frame.
direct bolt on if u have a cl-p. u wont have any clearance problems
Old Dec 31, 2009 | 11:15 PM
friesm2000's Avatar
B A N N E D
and your point is....
Rajca's Avatar
mdx already has the spacer. so u want to add another one?
