Programming Key Fob
No need for a trip to the dealer here's the deal.Hop in the car have both remotes ready.Now inser4t the key in the ignition in the lock and cycle it to the run position.Do not start the car simply get the lights in the Instrument cluster to come on.As soon as the lights come on hit the unlock button on one of the remotes.Cycle the key to off and then back to run and hit the remote again.You will have to repeat this quickly five times using the same remote.As soon as you hear the doorlocks cycle (audible thump in the door)leave the ignition on now quickly hit the lock button on the remote,then get the other remote and hit the unlock button snd then the lock button.The car will respond by cycling the door locks.It may require a few tries to do as you have to get the trick down with cycling the key and hitting the unlock quick enough for the car to enter the programming mode.Jens
Try searching next time
Thanks, NOVA! I'll give it a try! I tried a search earlier, but could not find anything. How far back do searches go? Is there a certain time frame.
Thanks again!
atClown
Thanks again!
atClown
soupi
14
11-15-2015 11:15 AM
