prank m90 supercharger adapter kit ?
Old 03-18-2016, 12:05 PM
  #81
h22cd7's Avatar
Originally Posted by richardparker
Nice,
Your car looks bad ass man.
Ive actually referenced pics of your car to friends to show what I was going to do.
what fuel pressure are you running?
and hows your afr look at idle and durring wot ?
fuel pressure was about 60psi, when we were doing the baseline we tried different intake pipes and we messed with the fuel pressure, originally i had it set at 65psi but we turned down to 60psi
afr were 11.5-12.1 around there but we figured it was safe until i can get the engine tuned
Originally Posted by 03 tls nc
h22cd7 that is sick!!! Are you still on J32A2 stock injectors with CLs ECU and Comptech ESM?
yup stock everything
Old 03-18-2016, 07:04 PM
  #82
3.7L Nitrous Breathing CL
richardparker's Avatar
Originally Posted by gnuts
What fuel pressure regulator do you have? Did you go colder plugs?
idk a vacuume one and 2step colder plugs.
RP I would like to see what kinda times I can put down, nothing serious. Will probably be mid May before I will have time to get down there, school is keeping my busy. Hit me up if you decide to head down to the track, I can probably get Boostedorbusted to come as well. It would be cool to have 3 blown CL/TLs at the track together.
From what I have found to keep your OBD2 working you have to piggy-back with Blue e-mange or AEM(boomslang harness has to be modified), up grade to 3gen tl and run Hondata (pain in the d***), or lastly splice in a stand alone an feed the stock ECU the right info to keep it happy.
I've been rocking ESM for about 50K now and haven't had any problems but a tune would sure make things nice! I've got a Blue e-manage but can't find anyone that has tuned one around here and I am pretty sure I will have to run larger injectors to be able to reap any benefits from it.
Why is your OBD port not working now? Thought you did a true 6speed swap?
Hell yeah we can do 3 at shady side.
I have a port now I just want to be able to tune the car and keep the port.
I need a tuning solution now.
The pulley I put on is showing 7-8psi and I can't even really get on it or it gets crazy lean and I'm not blowing up my engine.
Need a tuning solution NOW!!!
With some fuel the car will be fast as shit.
Old 03-18-2016, 08:46 PM
  #83
h22cd7's Avatar
whats your fuel pressure at now?
Old 03-20-2016, 09:41 PM
  #84
03 tls nc's Avatar
You can always swap your FPR(1:1) for an FMU(10:1) like comptech uses in there kits, it keeps you safe but does not give much fine adjustability. Cant find the link at the moment but someone was advertising an AEM standalone with wiring to plug and play with the true 6-speed wiring, this would let you put the factory ECU in to get your inspection then switch back or use a piggy-back. Either way you will need bigger injectors for any option besides FMU. Tuning is the hardest part about messing with these motors.
Old 03-21-2016, 10:27 AM
  #85
Dharma Member
ahxChun's Avatar
dezod is the company.
AEM EMS Acura CL Type S 01-03
03 tls nc (03-22-2016)
Old 03-21-2016, 02:38 PM
  #86
boostedorbusted's Avatar
I'm down with a little bit of shady side. LMK needa get this wheel hop under control.
Old 03-22-2016, 09:47 PM
  #87
03 tls nc's Avatar
Looks like it on for some Boosted fun at Shady side!!!
Are you still wheel hopping with the TLs wheels and sticky tires Justin?
RP I've got a Boomslang CLs 6peed harness for Greddy E-Manage laying around if you decide to go that route.
Old 03-23-2016, 10:36 AM
  #88
yeah still hops with the stickier tires. not sure what my next move is.
Old 03-24-2016, 07:26 AM
  #89
03 acura cl type s
rush's Avatar
I have a boomslang harness as well it never even started the car
Old 03-24-2016, 10:56 PM
  #90
03 tls nc's Avatar
RUSH did you ever run the E-Manage? Are you 6 speed or auto?
Old 03-25-2016, 03:14 AM
  #91
03 acura cl type s
rush's Avatar
nope I never used the E-manage and I'm 6spd
03 tls nc (03-27-2016)
Old 03-25-2016, 12:33 PM
  #92
Rawr.
Marcelechka's Avatar
After the initial install, only pickle we ran into was setting the voltage clamp to the correct setting preventing the map sensor from detecting boost. Once that was done, it worked flawlessly... heck, my tuner showed me how to adjust the fuel trims on my own so that I didn't have to bother him all the time .
Things did get complicated once we added more boost & meth though.
Regarding the Boomslang harness; be sure to purchase Product #BF10005 for the manual tranny. BF10006 is for the auto.
It's plug & play... no reason why the car shouldn't start as settings for the injectors, ignition, & idling are all factory settings detected on the stock ecu... The EMB only bypasses the factory ecu to manipulate certain things. IE: injector size, fuel trim +/-, idle, raising rpm, moving vtec, etc.
It's possible you may need to update the software in the unit? Or, you may have the wrong harness? Or the EMB unit is defective (if purchased used)?
I'd troubleshoot in that same order.
@Rush - you still you have my number?
Old 03-25-2016, 06:55 PM
  #93
I'm going to try a spa turbo adjustable fmu first,if the car dont like it then I will do a standalone.
It adjusts base fuel pressure and can adjust the fuel boost rate unlike a plain fmu.
It should help alot for cheap money.
If it does Ill be ready for a run or 2 In a couple of weeks.
Old 03-25-2016, 08:13 PM
  #94
Cant get on it but heres a quick 6psi clip.
20160318_192035_zpspukcx03r.mp4 Video by acuracl35 | Photobucket
Old 03-27-2016, 10:38 PM
  #95
03 tls nc's Avatar
Marcelechka thanks for the info on the EMB, nobody in this area wants to mess with it. Figured I would have to learn it for my self. Can you confirm the stock J32A2 injector size? I've found were some say 270cc and others say 310cc, I'm planning to run RDX injectors with the EMB but need to use proper calculation by the base injector trim. Any other info on setup of tuning the EMB would be greatly appreciated.
Old 03-28-2016, 08:03 AM
  #96
JarrettLauderdale's Avatar
This is more of a side note, but if you're wanting to use RDX injectors, they are a direct swap for J32A3 (same as J30A4/5) runners and fuel rails.
03 tls nc (03-30-2016)
Old 03-28-2016, 08:57 AM
  #97
Rawr.
No prob.
CL-S / TL-S @ 270cc
RSX-S @ 310cc
RDX @ 410cc (See Rajca's DYI here)
I ran stock injectors with the HBP; although with tune, it ran just fine.
When I ran the custom pulley, we went with Bosch Part: 0280-158-117 rated at 485cc. We modified the injectors to plug & play onto the rail. The EMB allows you to change the injector size, so we were good there. Where the issue lied was, when we started the car with the new configuration, the idle was VERY rough. Reason being, the stock ecu was thinking the stock injectors were plugged in and the EMB doesn't override until it reaches the set voltage (boost). So, instead of clamping it to detect any positive pressure, we set it well below (don't remember what voltage). From there, the EMB was technically running as a primary ecu since the voltage was set really low to override the stock settings from start.
It took a bit to get the various maps all set up along with the throttle positioning response... once done, the power was very linear. Took a whole weekend of street driving to this... constantly pulling over to adjust any & everything... the emanage made it happen though.
At the end of the day, the EMB is a great tool that's been proven to work. Give it a shot if you're capable; worked for me.
Apologies for the thread jacking RP.
The following 2 users liked this post by Marcelechka:
03 tls nc (03-30-2016), teh CL (03-28-2016)
Old 03-30-2016, 11:31 AM
  #98
03 tls nc's Avatar
RP have you had time to get the FMU installed?
JarrettLauderdale I have a complete 3G set up runners, rails, ect. Just need rdx injectors and plugs.
Marcelechka you are the man! Thank you so much. Will I need to use a 1:1 FPR instead of the Comptech FMU when running the larger injectors and EMB?
Old 04-01-2016, 06:08 PM
  #99
It showed up today.
going to remove my old regulator now,it will be in this weekend.
Old 04-01-2016, 07:18 PM
  #100
All I have to do is the return line .The return port on the adjustable fmu is larger than the return line so I need to wait till tomorrow to get some parts.
where can I get some good high pressure fuel line ?
Old 04-03-2016, 10:26 PM
  #101
03 tls nc's Avatar
PR take a quick trip to Denver / Maiden area.
TJ's Motorsports Warehouse
or
Hot-Rod express
Both stock High pressure fuel line and fittings, pretty much any thing you could want.
Old 04-04-2016, 11:08 AM
  #102
RP where does ur clutch setup start grabbing pedal height wise?
Old 04-10-2016, 07:05 PM
  #103
M90booosted
03-6/6's Avatar
i have questions.
i went to junkyard today and bought a m90 off a buick regal gs.
what size belt are you using?
what are you doing about the IACV?
Old 04-24-2016, 11:36 PM
  #104
M90booosted
03-6/6's Avatar
so.... updates? i ordered my plate tonight.
Old 05-09-2016, 04:13 PM
  #105
M90booosted
03-6/6's Avatar
got my order shipped today. i guess they ran out and i had to wait for some to be made. im so excited!
Old 05-29-2016, 01:15 AM
  #106
M90booosted
03-6/6's Avatar
started mine. The stock throttle body is causing a lot of issues. definitely need a b series.
Old 05-29-2016, 02:51 PM
  #107
03 tls nc's Avatar
What kind of issues?
Old 05-29-2016, 11:26 PM
  #108
M90booosted
03-6/6's Avatar
stock j series pulls from opposite side. it hits the blower case. also, iacv would be almost impossible because how big the port is and how close it is to the stock intake manifold.
i picked up a b-series throttle body today. ill work on getting it finished up tomorrow.
Old 09-29-2016, 08:00 PM
  #109
Well guys,my engine has seen better days.
It got hurt about a month ago and havent had to much time to get into it.
Got noise high in the lower end and compression went from 240psi in each cylinder to
210 in 4 and 130 and 110 in the other 2 in 8500 miles.
Ran car just motor,then nitrous,then motor,back to nitrous,then supercharged 4,6,8psi no tune ever. All was good until I put stock exhaust on.
Car didnt last a week after that.
8500 miles no tune and always killing it,not to bad.
8500 sounds short but that's 4yrs + of abuse.
So im at rebuilding for even more power or just giving up on it.
Thoughts ?
Old 09-29-2016, 08:19 PM
  #110
M90booosted
03-6/6's Avatar
why give up?
my stock a2 gave it up after 1-1.5k miles of no tune boost lol.
swapped j35a3 in and ordered the AEM fic which should be here tomorrow.
Old 09-29-2016, 11:19 PM
  #111
You ran this thing with no tune? I guess I don't ever remember you installing an aftermarket EMS, but now that I consider what this is powering, it sounds crazy! And here I am worrying that my high-compression J35A3 build isn't going to run on the stock ECU.
Old 09-30-2016, 10:39 AM
  #112
3.5 psi
gnuts's Avatar
Why not throw in a stock J35A3 and tune it. Or if you don't, then it's easy to throw in a replacement engine if need be.
Why did you put the stock exhaust on?
Old 09-30-2016, 10:41 AM
  #113
3.5 psi
gnuts's Avatar
Originally Posted by 03-6/6
why give up?
Does the FIC work with our 6speeds?
Old 09-30-2016, 05:04 PM
  #114
M90booosted
03-6/6's Avatar
yup. ordered boomslang PNP harness and the fic unit. will be installing soon.
Old 09-30-2016, 06:01 PM
  #115
3.5 psi
gnuts's Avatar
Keep us posted
Old 10-01-2016, 03:12 PM
  #116
03 tls nc's Avatar
RP hate to hear about the engine taking a dump on you, sounds like it could be broken ringlands. Roots super chargers produce a lot of heat, big free flowing exhaust is a must along with a rich AFR under boost. Tear it down and see how bad it is, worst case just drop a J35A3 in it for $300 and beat it up on the cheap, you have come this far why stop now.
Old 10-03-2016, 02:07 PM
  #117
Adam Kovach's Avatar
so this may be a dumb set of questions, but for the life of me I cannot find out how to run the belts? Do you need a different crank pulley for this?
Does anyone have the exact belts that would be needed to put this on the j32a2?
Old 10-03-2016, 09:18 PM
  #118
M90booosted
03-6/6's Avatar
i used oem pulley. have to route the power steering pump drain line in between belt. i think mine was a 66". i cant remember and it broke so i dont have it anymore. guess ill figure it out when i put it back on soon!
Adam Kovach (10-04-2016)
Old 10-04-2016, 08:37 AM
  #119
and the belt from SC will run from SC pulley to alternator to crank pulley?
Old 10-04-2016, 10:06 PM
  #120
M90booosted
03-6/6's Avatar
yup. had no problems. the first couple belts i used were loose, slipped in higher rpm. the last one i had worked good.
Adam Kovach (10-06-2016)
Quick Reply: prank m90 supercharger adapter kit ?
