Power Window Switch
Old Sep 29, 2003 | 06:30 PM
joelhe's Avatar
Power Window Switch
The driver side power window switch for the passenger side window on my wife's '97 3.0 CL is not working properly. It will lower but not raise the passenger side window. Fortunately, the passenger side switch works for both up and down.
Is the fix as simple as replacing the switch? If so, is this something I can do myself or is this better left to a dealer?
Thanks in advance - Joel
P.S. The lock switch is not on.
Old Sep 29, 2003 | 06:34 PM
RR32CLS's Avatar
"hey...wanna f^&k"
Re: Power Window Switch
this noob is good.
Old Oct 1, 2003 | 05:42 AM
Roleez's Avatar
Dealt with this B4... you'll have to disassemble the door to get to the window switch. Then you'll have to disassemble the window switch to get to the actual electrical copper contact points that are right below the window switch. Over time, these contact points become dirty and can cause erratic switch operation. Clean up the contacts, reassemble, and try them out again. (Also, even if the lock switch is on, the driver window switch should still work).
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
eastcoastguy
Sep 23, 2015 06:29 AM
