power steering noise when cold
Old Dec 19, 2008 | 09:48 PM
holeshot_04's Avatar
it's been well below freezing in Canada, like -8 to -12. in the morning the power sttering whines and the fluid look like its jell. power steering works just fine but its noisy untill its warm. is it doing damage? is it time for a flush?
Old Dec 20, 2008 | 01:47 AM
aznboi2424's Avatar
thats not good. the fluid should be..well fluid. I would see what the new power steering's temp ratings are and maybe flush it or see if synthetic fluid exists and if it is compatable with honda.
Old Dec 21, 2008 | 02:44 AM
krazykrnboi's Avatar
Wide Body 3.2 CL-S
uh... my pump made that noise... replaced and everything was fine. it only did it when it was cold... very annoying. new pump doesnt do that anymore... just my 2 cents
Old Dec 21, 2008 | 09:52 AM
poisx7's Avatar
are u sure its not frm ur belts.
maybe just some lillle rust/moisture on the pulleys.
use some anti squeak spray maybe................
or
maybe ur power steering pump bearing was already bad and its just showing it ugly behind now that its cold.
Becos I believe the PSF should be able to handle that low temp.
I agree with krazykrnboi too. I did the same becos i messed up the PSP bearing when I took off so fast of the line, ripped part of my PS belt hence damaging the bearing.
so I had to replace the whole PSP and belt...........
Old Dec 22, 2008 | 05:54 AM
the belt is fine. just replaced and tight. it might be the pump not sure. it only does it went the car is very cold. i'm gonna try flushing the fluid and go from there. if that don't work then the pumps next
Old Dec 22, 2008 | 11:25 AM
poisx7's Avatar
OK buddy Good luck with that.
Actually hope its just the fluids.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
