Poor Braking Performance Question
I have a 2001 CLS /w 180k+ miles. I just did my spring tune up with also included complete shock/strut replacement, guess one of my Koni's blew a seal over winter..oops. Have to say I love the Eibach Pro Kit, ride is really close to stock but it looks better and handles TONS better ahhh the joys of summer tires.
Any who.... the question I have is on my braking, I feel it sucks personally. I have had the warped routers, replaced by the dealer early on and then I've replaced those routers with the cheap parts store ones with the replacement warranty and have tried different pads throughout the years of owning. Right now I feel that I've lost alot of the original feel of the brakes and they don't feel like they are "biting" anymore. So while having everything apart I did a brake fluid flush and replacement with Honda fluid. They seem a little better now but still don't feel great. I was wondering if I should look at doing a caliper rebuild (or legend/nsx replacement) or as another thread mentioned replacing the master cylinder.
Ideas, things I can test/check?
'Cooter
a handful of options...big brake kits and budget a-la-carte options are available
i went with a-la-carte...rotors: DBA (Disc Brakes Australia) cd & slotted fronts, Rotora slotted rears...pads: Axxis Ultimate front & rear...Goodridge stainless brake lines
many people have gone with big brake kits that look and perform awesome...Brembo and Rotora are a couple examples
Replace the soft brake lines. New rubber is good the braided steel ones are best if you can find/afford them. I think the Braided Steel ones go for $80ish. A high performance pad will make a good difference too, but it seems you may have already tried that.
Heh, I guess I should mention the things that I HAVE done shouldn't I. Slow day and now coffee makes the brain go dumb.
- SS Brake Lines (Check, installed in '01/02 shortly after getting the car, the immediate feel of the brakes after doing this is what I'm looking to get back).
- Brake Pads (Hawk HPS street/sport pads, front only at this time)
- Front Rotors (Power Slot Power Alloy Cryo-Treated Rotor)
I thought I did a proper bedding of the brakes but after reading some more about it, I am going to go back and do it again (8-10 times from 60mph to 10mph and immediate accelerate afterwards, no complete stop, etc.).
Yup, thats the way I do it. I go to somewhere where there's little traffic and no lights then have at it. By the 6th time or so, the brakes fade from the heat. If you get out of the car and take a look, the rotors will turn have turned a slight blue and you can see/smell smoke.
Ultra Negro
personally I would stay away from hawk pads, from my actual track ans street experience, they suck, they honestly feel like stock pads, if you are into serious weekend warrior high speed autocross like me and my friend are, get you some carbotech pads and some cheap chinese rotors.
also if you can find some nsx calipers for cheap i would recommend those over the legend calipers just because it is a direct swap with no swapping of the caliper for the bleeder valve.
Maj Incident ResponseTeam
The NSX setup is direct fit for the CL? Nice! try looking into the Raybestos brand brakes (www.raybestos.com), they make stuff for cop cars and have products that fit on 01cl. i had them on other projects and have been happy with the results, good stoping power and they didnt fade as fast at the track. GL
Let me know how it turns out.
There must be a way to get that feel again without going to the legend calipers or bbks I assume. Could it be something with adjusting the brake pedal? Does it go out of spec over the years?
