Polarg M6 Question
Polarg M6 Question
Hey guys,
I have an 01 CL and I want to replace the stock fog light bulbs with the Polarg M6 bulbs ( These ). I did some searches and read through Chod's write-up page.
I noticed that his page is a few years old and I was just wondering if there was any new complaints about using the M6's or any reason I shouldn't use them.
Thanks guys
Thanks guys
Not Asian
Originally Posted by quicksilver10101
they look nice but they barely fit in side the hole and you must break them to get em out
You just need to slightly dremmel a little bigger hole and they'll slide right in/out.
i had polarg for about 4 months and after removing the bulbs i noticed some burnin scars......nothing big juss giving you a head up. I heard PIAA are good too, doesnt matter to me i took my fogs/roadlamps out
Not Asian
Originally Posted by Scottman111
Great, thanks a lot guys.
If I have any trouble I'll go with the dremmel tool method
"You my boi blue!"
Just some insight. I had the Polarg M6 in the road lamps and just had one go out in less then six months. I wore gloves and all so I wouldnt shorten the bulb lifespan. Wasnt too impressed after they burned out. I now have in the PIAA's and they seem brighter and better match to the HID's.
By the way I had to dremel the road lamp openings to fit the bulbs. I haev no clue how other people are getting them in without widening the holes.
GEEZER
Originally Posted by chriskh
I did a lot of searching on this before I made a purchase and found that the PIAA's are much less likely to melt the housings.
Acura loyal for 93mo/109k
Hmm PIAA's huh... Thanks for the suggestion. Can someone link to which ones they used, please?
BTW...for others not familiar with the CHOD link...http://wizardsworks.org/chod/acura/m6/ Good instructions & pics for getting at the bulbs alot easier.
EIther one wont fit unless you dremel the hole.
"You my boi blue!"
Originally Posted by OneFlyCL
It'll fit...you just gotta force it a little.... mine fit almost perfect for some reason, maybe i m just perfect
Kudos for getting them in without breaking one! At first I tried to gently push them inward but i said no way in doin it without busting the bulbs. Maybe you are the next David Copper-Field pulling that one off
I got the bulbs in OK, but removal was trickier. I then used a piece of sandpaper wrapped around a pencil to enlarge the hole ever so slightly. Replacing a burnt bulb is now a breeze and can be done in 5 minutes.
Hey everyone how was your holidays?
Thanks for all the responses. From what I've read on here and other places I think I'll probably end up going with the PIAA's.
Thanks for the help and suggestions!
A clean ride is in
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
