Please please please i need everyones help!!!
Old Oct 13, 2004 | 09:47 AM
  #41
sidemarker's Avatar
i should get news today if they will cover it under warranty!
hope i dont get screwed!
sidemarker
Old Oct 13, 2004 | 01:42 PM
  #42
car_lost's Avatar
sidemarker
good luck!
Old Oct 13, 2004 | 07:27 PM
  #43
Chopsie's Avatar
Beware of leakage
Originally Posted by allmotor_2000
With VTEC you have a high lift/duration cam lobe which is used after a certain RPM. Oil pressure (controlled by the VTEC solenoid) pushes a pin which locks the center lobe (high profile 'vtec' lobe) to the rocker assembly. When not in 'vtec', the regular (or adjacent) cam lobes are used. On SOHC VTEC cars, the extra lobe is only available on the intake side while on the DOHC VTEC cars, it is available on the intake and exhaust side. On the new i-VTEC motors, you get cam timing adjustment in addition to variable valve lift - its like having an adjustable cam sprocket which adjusts as RPMs change!! I believe this is only active on the intake-side, but I may be mistaken. I am sure the new NSX is DOHC i-VTEC - meaning variable valve lift and cam timing on the intake and exhaust!!
If you open up an integra DOCH VTEC motor, you will see three rocker-arms/cylinder on each side. The center one is used only during VTEC - The cams also have three lobes/cylinder with the center one being the 'hi-cam' or 'vtec' profile.
I see what your saying, but still don't fully understand, it's ok, excellent explanation . If only there was a moving illustration to show the VTEC cam coming into play.
Old Oct 14, 2004 | 01:30 PM
  #44
aznite's Avatar
Good luck with that man. I was always under the impression that adding mods to your car did void the warranty and thats why i haven't done anything yet, gets me thinking about a new intake and exhaust. *grin*
ITSJESTER
17
Dec 6, 2018 02:29 AM
emailnatec
29
Sep 28, 2018 04:27 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
rhdune16
Sep 28, 2015 11:31 AM
