Please help p0336
Old Jun 16, 2017 | 12:20 PM
Mtmill99's Avatar
5th Gear
Please help p0336
getting code p0336 it is a 2003 cl-s6 I have tested and changed both sensors I am getting the correct voltage to and from sensors the only thing I haven't changed is the ecu but after reading forums here that is not fixing the problem has anyone got any advice as I don't want to give up yet as the car only has 80000 miles on it
thanks for any help
Old Jun 16, 2017 | 12:27 PM
No need to create another thread, your question was answered here:
https://acurazine.com/forums/2g-cl-p...-p0336-957910/
Old Jun 16, 2017 | 03:59 PM
Karanx7's Avatar
Unregistered Member
thanks for any help
.... < Here's some periods if you want to sprinkle those into your run on sentence.
? < In case you have a question, you can use this too.
Old Jun 16, 2017 | 04:23 PM
Mtmill99's Avatar
5th Gear
I guess everyone has to be an ass and not help
Old Jun 16, 2017 | 04:33 PM
Karanx7's Avatar
Unregistered Member
Hmm, still didn't use a period.
But seriously, you have 3 posts total. All of which are asking for help with poor grammar and no introduction. If that's how you ask for help, you may not get any. Maybe someone nicer than me will help you.
Old Jun 16, 2017 | 04:55 PM
thanks for any help
Your next step, unfortunately, if you want to salvage the car, after replacing and testing for correct voltage to/from the sensors, is to acquire a used ECU. If you search car-part.com for either 'Engine Computer' or 'Computer Box Engine' you will find that there are only five available throughout the country and they are not cheap. I believe, if possible, try and get the keys with the ECU to save time with reprogramming those.
Furthermore, just because fsttyms1, on the other thread, did not have initial luck with his new ECU replacement, he did state that the car sat awhile and it eventually came to its senses and started. Otherwise, you may need to take the car to the dealer, pay more money in diagnostics, to get any further insight as to what might be going on.
https://acurazine.com/forums/second-...ed-ecu-949666/
Good Luck!
Old Jun 16, 2017 | 09:00 PM
Mtmill99's Avatar
5th Gear
The honda dealer won't look at it near me and the Acura dealer is 100 miles away. I can't seem to find any threads that anyone has fixed this code in the manual transmission version other than the one with the broken aftermarket flywheel. I will try to find a computer and thanks for the info.
Old Jul 1, 2017 | 03:31 PM
Mtmill99, did you ever get this issue resolved on your 80K mile CL-S6?
Old Jul 1, 2017 | 09:56 PM
Mtmill99's Avatar
5th Gear
No I haven't got it fixed yet. I plan on sending the computer off the the guy on eBay that works on them to see if that fixes it. It will be cheaper than replacing the computer then having to reprogram the key.
Old Jul 2, 2017 | 06:37 AM
Interesting, if possible, could you provide a link that describes the ECU services the eBay guy provides?
Old Jul 3, 2017 | 09:26 AM
johnboy1313's Avatar
Does the engine run or just crank?
