Please help p0336
Please help p0336
getting code p0336 it is a 2003 cl-s6 I have tested and changed both sensors I am getting the correct voltage to and from sensors the only thing I haven't changed is the ecu but after reading forums here that is not fixing the problem has anyone got any advice as I don't want to give up yet as the car only has 80000 miles on it
thanks for any help
thanks for any help
No need to create another thread, your question was answered here:
https://acurazine.com/forums/2g-cl-p...-p0336-957910/
thanks for any help
thanks for any help
? < In case you have a question, you can use this too.
Hmm, still didn't use a period.
But seriously, you have 3 posts total. All of which are asking for help with poor grammar and no introduction. If that's how you ask for help, you may not get any. Maybe someone nicer than me will help you.
thanks for any help
thanks for any help
Furthermore, just because fsttyms1, on the other thread, did not have initial luck with his new ECU replacement, he did state that the car sat awhile and it eventually came to its senses and started.
Otherwise, you may need to take the car to the dealer, pay more money in diagnostics, to get any further insight as to what might be going on.
https://acurazine.com/forums/second-...ed-ecu-949666/
Good Luck!
The honda dealer won't look at it near me and the Acura dealer is 100 miles away. I can't seem to find any threads that anyone has fixed this code in the manual transmission version other than the one with the broken aftermarket flywheel. I will try to find a computer and thanks for the info.
No I haven't got it fixed yet. I plan on sending the computer off the the guy on eBay that works on them to see if that fixes it. It will be cheaper than replacing the computer then having to reprogram the key.
