PLEASE HELP!!! - Erratic Idling
Old Dec 11, 2005 | 03:37 AM
AngrYmUthAfAUkEr's Avatar
I have been having a problem when I start my car. I turn the ignition and the needle on my rpm gauge goes up to 1000 rpm and loses strength, making the rpm go down to 0 and the car shutting off. Then, I turn the ignition again the rpm keeps fluctuating from 1000 rpm to 1500 rpm, going up and down. I was thinking spark plugs was the problem but the car's an '01 and has 68000 miles on it. It doesn't always do this when I start the car though. Sometimes the car starts fine; it seems to happen when I drive the car around, I turn the engine off, and come back to start the car in 15 minutes to an hour. I have no idea what the problem is and what to do to fix it before it becomes a problem. PLEASE HELP!!!
Old Dec 11, 2005 | 06:41 AM
Sun Diego CL-S's Avatar
says "hello to my TLX".
run that by once more. you DO and DON'T have a problem?
you know, that sounds similar to the problem i had with my cars IACV (idle air control valve). so that just might be it. do you have any lights flashing in your face?
Old Dec 11, 2005 | 08:16 AM
typeR's Avatar
an idle air control valve or any vacuum leak
Old Dec 11, 2005 | 12:06 PM
Chopsie's Avatar
Beware of leakage
Sounds Idle air control valvish to me
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
Skirmich
Oct 1, 2015 12:59 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
