Pirelli Pzero Nero in stock size?
Pirelli's web site shows this tire is made in a 215-50-17", but I cannot find it anywhere
Bad info from Pirelli or too new for dealers to have yet? It has a higher load rating than stock and is "Y" rated. I really don't care about the "Y" speed rating, but I do want a replacement tire that has a load rating equal to or greater than the 93 of the stock tires. It seems a lot of the problems people have with pot holes is that they are using tires with a load rating below 93. Christ, the front end of this car is a pig with the amount of weight over the front wheels. What else is out there in the stock size with a 93 or better load rating?
Dan
Bad info from Pirelli or too new for dealers to have yet? It has a higher load rating than stock and is "Y" rated. I really don't care about the "Y" speed rating, but I do want a replacement tire that has a load rating equal to or greater than the 93 of the stock tires. It seems a lot of the problems people have with pot holes is that they are using tires with a load rating below 93. Christ, the front end of this car is a pig with the amount of weight over the front wheels. What else is out there in the stock size with a 93 or better load rating?Dan
http://www.victoriatire.com/tires.ht...o%20Nero#sizes
Tirerack doesn't have your size nor does it have my 235/45/17's either...but VictoriaTire has em, AND my size has an even higher load rating than yer 215's...good news is you can still get the 235 series on stock rims, so i would consider that size if you want to stick with 17's
When i purchased my tires back in august of 03, i wanted to get the nero's i spoke with a rep from pirelli and at that time they said that tire will be offered in the 215/50/17 size but was only to be going into productiong in december of 03.
My guess is they still haven't started production on them. I ended up purchasing a set of 215/50/Y17 Asimmetrico's and they are performing pretty good in my opinion.
Mugen TSX
Eastern Canada
Sep 16, 2015 09:52 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
