Pics of my car
Old Apr 6, 2001 | 01:44 PM
4mula1's Avatar
Pics of my car
A few pics of my cars mods. I have not tried to post a link before, so if this does not work and anyone is interested let me know how.
http://albums.photopoint.com/j/ViewP...744&p=45837098
Old Apr 6, 2001 | 01:49 PM
SJ Silver Type-S's Avatar
Looks good, but a bunch of your pics don't load. I would like to see more of your stereo.
CoMpTeCh HeAdErS
eIbAcH sPrInGs
AeM cAi
Old Apr 6, 2001 | 01:51 PM
buddha's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 4mula1:
</font>
Tell me more about the speaker set up.
Old Apr 6, 2001 | 02:02 PM
4mula1's Avatar
I"ll try to take a few more pics soon.
I replaced the stock Blose with MB Quarts, Oh what a difference! The rears were a little too deep, the magnets were touching the trunk bars that go across the trunk. I placed some high density weather stripping between the speaker and the hole and it gave just the clearance that I needed.
Same token for the front speakers, they were too deep for the doors. I had to build the mount out a little, works fine can't even tell they are there. The tweets fit right in no modification required. There is plenty of room in the doors for crossovers.
I mounted the amp to the underside of the decklid using some aluminium brackets.
I am posting a couple more of the stereo as I write this. I will take some better pics today.
Old Apr 6, 2001 | 02:03 PM
4mula1's Avatar
Old Apr 6, 2001 | 02:07 PM
tuleman's Avatar
Learn to swim
Nice... Those are comptech springs? Do you have stock shocks? Your car seems to sit a little lower and a little more even than mine.
I also like the red A in the front. I have been thinkng of doing that myself. What kind of paint did you use? Did you use the same paint to paint your calipers?
01 CL-S Black/Tan
Comptech Springs, V1
Old Apr 6, 2001 | 02:15 PM
4mula1's Avatar
The red on the Acura emblem is vinyl, its the material that stickers are made out of. Go to any local sign shop and they should be more than happy to sell you a small piece.
Comptech springs and stock shocks, It might be the angle of the picture that makes the stance look different.
Old Apr 6, 2001 | 02:24 PM
WebToker's Avatar
</font>
Where did you get the paint for you calipers and what kind did you get? BTW you ride is looking sweeeeet and cleannn.
2001 Acura 3.2 CL Type-S
Comptech Springs
Comptech Exhaust
Denso Spark Plugs
Apexi V-AFC
AEM CAI
Old Apr 6, 2001 | 02:45 PM
4mula1's Avatar
I picked the paint up from a local speed shop
(Paragon Tuning), I can't remember the name of it right now. I'll post it when I get home and look at the can.
Old Apr 6, 2001 | 03:04 PM
[VTEC]TL's Avatar
RWD convert
How much did u pay for the paint? Spray or brush-on? Also, did u remove your calipers to paint them???
Y2K Satin Silver/Ebony 3.2TL
AEM Short ram w/ custom CAI conversion | Magnaflow axle-back exhaust | Neuspeed Sport springs(modified: 3.5"F/3"R drop) | BOSCH platinum+4 spark plugs | Acura OE Wing | Mesh grill and bumper | Acura Indiglo Emblem | Mugen badging | Body color door handles | Polarg M12 sidemarkers | Opti-Blue Xenon HB's | Hiper Strobes F/R | 20%/35% Llumar Platinum tint | Razo RA42 Shiftknob | Alloy pedals | Blue neon exterior lighting | Rockford 10" RFP2410 Punch XLC subs | Boss Audio CLR60 600watt 4ch. amp | Escort Passport 7500 Radar/Laser detector
Old Apr 6, 2001 | 06:03 PM
dboy619's Avatar
Sweet car and audio setup! Would you mind giving me an idea of how and what configuration you used with your 5-ch Soundstream amp, speakers, stock deck and... and the electronic crossover????
Thanks a bunch.
Old Apr 6, 2001 | 07:16 PM
4mula1's Avatar
Well I got the idea from Astroboy. I saw the how clean the Alpine G190 looked in his dash , I knew it was what I wanted to do.
I wanted to maintain the stock look, and the remote on the wheel, but I needed better sounding speakers and some low end.
I did this install in stages, and I am still working on the amp placement and the sub. I am going to go with a single ten dual voice coil after I sell the twin JL tens.
The front speaker output on the stock deck is
wired directly into the line level input on the Alpine sub proccessor.
The sub proccessor has three outputs (front rear and sub) These are routed down the center of the car on the passenger side, where they hook into the amp.
The remote and the power wires for the Alpine are tapped right into the wiring harness behind the head unit.
The remote to turn on the amp runs from the proccessor past the driver floorboard and down the driver side of the car till it reaches the amp.
The Power wire is run from the battery through the fire wall (existing Gromit) down the driver side to the amp.
The speaker wires run from the amp to rear speakers. For the front speakers I ran the speaker wire the same way I ran the RCA's to the amp(down the center of the car.
The crossovers are in the door panel, where they are wired to the 6 1/2 mid and the tweeter.
Anything to remove those Blose from my car.
I removed the Bose amp from the trunk, no need to carry around that piece of crap.
I think I will build a custom enclosure for a ten in the near future.
Thanks Astoboy.
Old Apr 7, 2001 | 01:41 PM
4mula1's Avatar
I have posted more pics of the stereo setup for those that were interested. a pic of the new tweeters, the trunk, amp wiring.
To answer the caliper paint question. The calipers were removed before I painted them. I beleive it was from foliatech, but I don't have the can anymore so I may be wrong. The can of paint cost me 15 bucks. I think I got taken for a ride. I think it is possible to use automotive engine paint on the calipers and achieve the same effect. That only cost 4 bucks a can and you can get it at Pep Boys or a store like that.
Old Apr 7, 2001 | 01:55 PM
CO-CL-S's Avatar
Nice ride, I especially like the Bare Butt! I haven't gotten to my RockFord 200a4 to replace the stock amp. and 150a1 with MS310 for sub in the rear, but you are an inspiration to get on it. tks.
Eat Safe, Use Condiments
red CL-S, non-Nav, 35% tint, M6 driving lights, M4 map and door lights
Old Apr 10, 2001 | 12:54 AM
nkycls's Avatar
where did u get that red emblem, i thought you need a oversized emblem for the grill, please let me know where u found that and the price
GhostTL09
Sep 19, 2015 01:57 PM
V12 Inspire
Sep 10, 2015 04:46 PM
BlueAquarian
Sep 10, 2015 02:18 PM
bymotion
Aug 31, 2015 05:00 PM
