Performance Suspension Part#'s Request
Old Mar 18, 2020 | 09:22 AM
Acura2g558's Avatar
Small story... I'm rebuilding a lightly neglected 03 CL-S6 w/ 95k on it as a fun project car that I'll drive during the summer. I've done a ton of work using oem parts to bring it back to it's glory. I want to bring the cars drive-ability and handling into this decade but I'm having a hard time finding suspension parts that are known compatible with the CL. I don't want to cross my fingers on accord parts working without some assurance because it was cause headaches and likely lost money. I found some information on the forum regarding radius arm bushings using ES #16.7103 which appears to be a direct fit to the CL and looking it works with many other Acura/Honda's too. So here's my question which i'm having a hard time finding and maybe this can become a comprehensive post for others too.
Bushings
  1. Radius Arm Bushing
    1. Poly Bushing: Energy Suspension - Part # 16.7103
    2. Poly Bushing: Moog - Part # MOOGK9733
    3. Rubber Bushing: AC DELCO Professional Part # 45G25002
  2. Sway Bar Bushing - Front (27.2mm)
    1. Poly Bushing: ???
    2. Rubber Bushing: AC DELCO Professional Part # 45G0881
  3. Sway Bar Bushing - Rear (19mm) - Type-S
    2. Rubber Bushing: AC DELCO Professional Part # 45G1513
  4. Sway Bar Bushing - Rear (18mm)
    2. Rubber Bushing: AC DELCO Professional Part # 45G1505
  5. ​​​​​​​Front lower Control Arm Bushing
    1. ​​​​​​​Poly Bushing:???
  6. ​​​​​​​Front Upper Control Arm Bushing
  7. ​​​​​​​Rear Lower Control Arm Bushing
    1. ​​​​​​​Poly Busing:???
Aftermarket Struts and Shocks
  1. Front
    1. ​​​​​​​KYB - AGX: Part # 741049
    2. Bilstein B6 Performance: Part #24185714
  2. ​​​​​​​Rear
    1. ​​​​​​​KYB - AGX: Part# 741050
    2. Bilstein B6 Performance: Part #24185721
    3. Bilstein B8 Performance: Part#24185738
  3. Front and Rear Combo Kit
    1. ​​​​​​​BCRacing: Part# A-05-BR
Appreciate any knowledge on suspension parts to fill in gaps I have to these. I'll update the original post to make it easier on everyone. Does anyone know if there is an ES master kit that is compatible too?
Old Mar 18, 2020 | 09:25 AM
Acura2g558's Avatar
Darn... Mods move this to "Suspension" category. My bad.
Old Mar 18, 2020 | 09:41 AM
Acura2g558's Avatar
Sway Bars:
  1. Eibach Front (27mm) Rear (23mm) Part # 4040.32
Old Mar 18, 2020 | 10:40 AM
Originally Posted by Acura2g558
Sway Bars:
You've probably already seen these; however, here's a set for $50 in the Black Market section of the forum.
https://acurazine.com/forums/market/984595
He also had a set of springs Part No. 4041.140 which should fit your CL, if interested.
https://acurazine.com/forums/market/984594
Sure beats retail if he still has them.
I have the ES radius rod bushes on my 6 speed and they fit, others have used the Moog's as your research reveals.
When my outer OEM LCA bushes started to crack, I first went with Moog replacements from rockauto; however, in less than a year the moogs started to fail. I went back to OEM's and have them to this day. I replaced the inners (which were OK) when I did the outers because I did not want to dick around with those two large RR bolts on the LCA again.
I have the comptech front and rear sways, from back in the day, so I can't speak about the Eibach's. Front OEM sway bushes were used during the install and CT provided, what looks like a poly, with the kit, though I'm not sure. Still have them on to this day with no problems. Still have the OEM upper fronts and rear upper and lower control arm bushes.
Old Mar 18, 2020 | 10:47 AM
Acura2g558's Avatar
I saw those on the marketplace and PM'd but never got a reply. So sad too because i really wanted them, especially for that price
Old Mar 18, 2020 | 10:57 AM
Try bumping his BM thread(s) with a reply. Not sure if the forum sends an email notification to his primary email with just an inner private mail message. That way he may respond, although it looks like Jan2020 was his last login date.
Ballinger
129
Sep 15, 2017 02:42 PM
aragrev7
1G TSX Photograph Gallery
Aug 8, 2014 01:48 PM
tri2tun
Feb 5, 2011 08:11 PM
henrylo
Aug 11, 2010 01:13 PM
alexSU
May 28, 2010 01:04 AM
