Performance Suspension Part#'s Request
Small story... I'm rebuilding a lightly neglected 03 CL-S6 w/ 95k on it as a fun project car that I'll drive during the summer. I've done a ton of work using oem parts to bring it back to it's glory. I want to bring the cars drive-ability and handling into this decade but I'm having a hard time finding suspension parts that are known compatible with the CL. I don't want to cross my fingers on accord parts working without some assurance because it was cause headaches and likely lost money. I found some information on the forum regarding radius arm bushings using ES #16.7103 which appears to be a direct fit to the CL and looking it works with many other Acura/Honda's too. So here's my question which i'm having a hard time finding and maybe this can become a comprehensive post for others too.
Bushings
Appreciate any knowledge on suspension parts to fill in gaps I have to these. I'll update the original post to make it easier on everyone. Does anyone know if there is an ES master kit that is compatible too?
Bushings
- Radius Arm Bushing
- Poly Bushing: Energy Suspension - Part # 16.7103
- Poly Bushing: Moog - Part # MOOGK9733
- Rubber Bushing: AC DELCO Professional Part # 45G25002
- Sway Bar Bushing - Front (27.2mm)
- Poly Bushing: ???
- Rubber Bushing: AC DELCO Professional Part # 45G0881
- Sway Bar Bushing - Rear (19mm) - Type-S
- Poly Bushing: ???
- Rubber Bushing: AC DELCO Professional Part # 45G1513
- Sway Bar Bushing - Rear (18mm)
- Poly Bushing: ???
- Rubber Bushing: AC DELCO Professional Part # 45G1505
- Front lower Control Arm Bushing
- Poly Bushing:???
- Front Upper Control Arm Bushing
- Poly Bushing:???
- Rear Lower Control Arm Bushing
- Poly Busing:???
- Front
- KYB - AGX: Part # 741049
- Bilstein B6 Performance: Part #24185714
- Rear
- KYB - AGX: Part# 741050
- Bilstein B6 Performance: Part #24185721
- Bilstein B8 Performance: Part#24185738
- Front and Rear Combo Kit
- BCRacing: Part# A-05-BR
You've probably already seen these; however, here's a set for $50 in the Black Market section of the forum.
https://acurazine.com/forums/market/984595
He also had a set of springs Part No. 4041.140 which should fit your CL, if interested.![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
https://acurazine.com/forums/market/984594
Sure beats retail if he still has them.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I have the ES radius rod bushes on my 6 speed and they fit, others have used the Moog's as your research reveals.
When my outer OEM LCA bushes started to crack, I first went with Moog replacements from rockauto; however, in less than a year the moogs started to fail. I went back to OEM's and have them to this day. I replaced the inners (which were OK) when I did the outers because I did not want to dick around with those two large RR bolts on the LCA again.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I have the comptech front and rear sways, from back in the day, so I can't speak about the Eibach's. Front OEM sway bushes were used during the install and CT provided, what looks like a poly, with the kit, though I'm not sure. Still have them on to this day with no problems. Still have the OEM upper fronts and rear upper and lower control arm bushes.
Ballinger
129
09-15-2017 02:42 PM
