Performance Gain from Chip
Old Apr 16, 2003 | 08:47 PM
schoeny14's Avatar
I was looking for a good chip for the CL, and i found one from www.jetchip.com . They say HP gains for the 2003 6 speed are between 8 and 13 HP. I was wondering what you guys think or if you knew of a better chip out there.
Old Apr 16, 2003 | 08:51 PM
AztecRol's Avatar
The Screeching Toyo's
Ask scalbert, he is looking into one as well. He posted something about it in a thread about his Pulley Upgrade for his Super Charger.
Old Apr 16, 2003 | 08:59 PM
NOVAwhiteTypeS's Avatar
chips are ususally only good for forced inductions , try a v-afc
Old Apr 16, 2003 | 10:40 PM
PiMpiN wHITe Cl-S's Avatar
do you know if they make any for a 01 cl-s..and how what would it be??..i looked around on the site and didnt find anythin..thanks
Old Apr 16, 2003 | 11:05 PM
mattg's Avatar
i don't think we've ever seen dyno proof from Jet.
Old Apr 16, 2003 | 11:11 PM
ferrari528's Avatar
Old Apr 17, 2003 | 07:25 AM
Ray Khan's Avatar
yes, with forced induction chips control the wastegate and let you run more boost. BUt I would think even in NA setup a chip is better than a VAFC....With a chip you can add soe timing along with setting the fuel/air mixture to optimal. VAFC only lets you play with the mixture right? Either way it's a minamal gain and I wouldn't jump at a chip until it's been dynoed and proven to be safe. Too much timing can kill!
Old Apr 17, 2003 | 08:40 AM
fuzzy02CLS's Avatar
That Jetchip module is crap! It isn't a chip. It a little black box with some idiot lights, & a knob. I had it on another car, & it decreased my HP at lower RPM, & gained 2 at high RPM. It's really the same modual for all speed density cars. Speed density is when the car uses MAP, & TPS sensors instead of a mass air sensor. It changes the fuel/air curve a little. That's it. No other changes are made. No shift points, no RPM limiter removal. It also fried 2 MAP sensors on the car I used it on.
Old Apr 17, 2003 | 08:50 AM
juniorbean's Avatar
I agree with the masses here. Over a year ago there was someone on here who purchased a Jetchip and did get a dyno. I don't remember his setup (definitely didn't have an S/C or turbo), but when he dynoed I believe he actually LOST power!! Unless they've come out with a "new" version I would be very careful going this route as we've yet to see any independant dynos showing any power gains.
Old Apr 17, 2003 | 01:22 PM
schoeny14's Avatar
thanks for the heads up on the jet chip....you guys know of any other chips that are actually any good for the money?
Old Apr 17, 2003 | 01:24 PM
CLpower's Avatar
teh Senior Instigator
someone did it a LONG time ago and actually lost power!
don't do it
Old Apr 17, 2003 | 01:28 PM
CLpower's Avatar
nothing really, unless you want to go stand alone and do the AEM EMS. But nothing has been proven w/ that on our cars either.
Old Apr 17, 2003 | 04:54 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
You cant chip it. Everything is hardcoded into the computer.....you need a piggyback...because the auto is run by the ECu as well.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
