to people with audio
Old Sep 25, 2006 | 10:08 PM
Techniques's Avatar
i just got a JL W6 10" and a loaner JL amp. i want to hook it up soo bad. but my friend isnt sure if our stock deck has the input or output on the back? has anyone hooked up there audio to there stock deck?
Old Sep 25, 2006 | 10:54 PM
KahRupt-CL-S03's Avatar
B A N N E D
No, it does not have the output but you can adapt a RCA converter which will bypass your speaker outputs and have RCA outputs at the end of the converter, with this you can add an amp.
BTW you can cut the OEM harness (not recommended) or get a metra harness and play with that. Very easy to do, search and post in audio section next time
Good luck
Old Sep 25, 2006 | 10:55 PM
BaumBizzle's Avatar
use the search man, thats what its there for......but to help there are no RCA inputs or outputs on the stock deck, thats what I got for searching
Old Sep 25, 2006 | 11:27 PM
BigLizard's Avatar
Moderator Alumnus
I would not recommend using the stock deck...you can blow it very easily. bose car stereo and you'll notice just about anything is not recommended hooking up to the stock deck.
Old Sep 25, 2006 | 11:37 PM
B A N N E D
It could, if you do not know what your doing, but if done by a pro, there is "no way" it will blow, there is no input into the stock radio, that is why there's a conv, so that nothing goes into the receiver but the speakers
Old Sep 25, 2006 | 11:56 PM
BigLizard's Avatar
Moderator Alumnus
I know...I just wouldn't recommend doing it if he was a novice.
Old Sep 26, 2006 | 12:06 AM
Techniques's Avatar
well i tried searching for a bit but nothing came up. but yea my friend's brother in-law owns a shop and hes doing it for me.
Old Sep 26, 2006 | 12:09 AM
Techniques's Avatar
are the converters expensive? if its too expensive i might aswell by a deck
Old Sep 26, 2006 | 08:02 AM
GreenMonster's Avatar
A/V forum is for question like this since it isn't model specific (TL, TSX, CL all can use the same audio equipt):
https://acurazine.com/forums/audio-video-electronics-navigation-22/
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
