overflow tank
overflow tank
***** to put back in if you take it out. had to pour antifreeze out of overflow tank to be able to minipulate it on that small hanger it slides on. No room for your hands. I was just checking to see if any antifreeze in it since you can't see it unless you pull it out. WILL NOT DO THAT AGAIN unless it's spewing steam.
Someday pigs WILL fly!
Really? When I took mine out, I had no problem. It's been awhile but I don't recall any trouble whatsoever. ![](http://www.acura-cl.com/ubb/confused.gif)
01 CL-S NightHawk Black/Ebony Bowling Ball Interior
Loisn:take the cap off and shine aflashlight down the opening,then you will see on the outside of the bottle how much coolant you have.Add 50/50 as required.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
mrkingstonvi
02-22-2016 01:53 PM
