Oil question
Oil question
I want to change my oil soon but I want to use synthetic but the last car I had it had been on regular oil its whole life and when we added synthetic the rear main seal started leaking. It might have been something else but I think thats what it was. So will using synthetic on a car that has been on regular oil its whole life create leaks? I just want to make sure so my new car will remain leak free.
mod edit: changed title from "question" to "Oil question". Having descriptive thread titles will get better answers (and thread views).
well Im not sure but I think the car came with synthetic from the factory.
are you looking for full-synthetic or are you gonna use a synthetic blend?
and just restating because im sure you know, that once you change to a full synthetic oil you cant use conventional oil again unless you want to mess up your engine
it shouldnt leak. if you want, you can make a more gradual change over buy using a synthetic blend for a few oil changes before going fully synthetic but i dont know if that will do anything.
advance auto is having a special right now on mobil 1. You can pick up 5qts + oil filter for 29.99 + tax. I went ahead and bought 3 sets of them.
I have a slight Rear Main Seal leak now. Kinda sucks but it doesnt really have any detrimental effects upon the car that I can see. Going to do clutch/flywheel in 10k or so, so i'm not worried.
Also when you make a new topic, please please please be a bit more descriptive with your title!!!!!!
And I have 187000 KM on mine I think thats 110 miles
on Another note Is honda OEM trany fluid sythetic because I want to put synthetic in my trany but The acura dealershiip siad dont put anything but OEM honda fluid (I knew they were goin to say that they say that for every thing) Oh its an 01 CL-SA
If you want to try Mobile 1, the thread below may save you some money.
https://acurazine.com/forums/2g-cl-2001-2003-50/mobil-1-%2410-%2420-rebate-709770/
I agree Ive already switched back and forth twice no issues
http://www.amsoil.com/storefront/mtf.aspx
this is what it says
Replaces Honda Genuine MTF fluid for manual transaxles and Texaco MTX fluid.
his 01 is an auto. in auto trannies, use either honda ATF or something that is honda ATF-Z1 approved.
what kind of filter do they give you?
note the starting purchase date for that rebate is april 1st.
https://acurazine.com/forums/showthread.php?t=709770
Theoretically it shouldn't make a difference. But it isn't unheard of for engines with questionable maintenance histories to begin having oil leaks after switching to synthetic oil at a high mileage.
Generally, if the engine has been maintained properly it should not make a difference. If the maintenance is history is questionable, then I would proceed cautiously. Also, rear main seal leaks aren't uncommon on Honda V6 engines, regardless of oil used, if the engine has been poorly maintained.
There's no such thing. The only ATF-Z1 that is Honda approved is the one that you purchase at the dealership. This is because Honda does not have a fluid licensing program like GM, Ford and Chrysler.
However, Lubrizol, which is one of the largest additive suppliers, has a multi-vehicle additive package that has been bench and field tested extensively in a variety of popular applications, including Honda. Therefore, you'll find many over-the-counter multi-vehicle fluids that list Honda ATF-Z1 compatibility, but not approval.
So this is why I want to go synthic with my CL-SA.
I did put synthtic engine oil in the CL ,didnt notice a difference in longevity.
I put it in my 88 300zx(160 000 Km) and it totaly destoyed my gas milage
Just thought you guys might want to know some wierd things that happened to me with synthetic engine oil.
damn, thats a good deal then. too bad there isnt a advance auto in cali.
as long as you maintain a good interval in your oil changes, there shouldnt be too much sludge.
If your car has over 75k, i, personally, would use a high mileage oil. My mom's camry was blowing out white smoke on cold starts and after a few oil changes of valvoline maxlife, it doesnt smoke anymore. theres 220700 on the engine right now.
BoricuaTL
04-08-2016 01:08 PM
IIDXholic
10-08-2015 07:53 AM
