Odd AC Problems
Old 07-18-2007, 09:55 PM
o1s
o1s's Avatar
Odd AC Problems
i have noticed my a/c acting up every once in a while over the last couple of days. every once in a while at idle, it sounds like the compressor clutch is engaging and instantly disengaging again. what would cause that? i can't live without a/c. it is 95+ degrees every day here. any suggestions?
Old 07-19-2007, 07:59 AM
fuzzy02CLS's Avatar
So the compressor is cycling a lot? That's a symptom of low freon.
But also could be the clutch cycle switch.
You would need to hookup a pressure gauge to troubleshoot it.
Old 07-27-2007, 08:25 PM
o1s
o1s's Avatar
i found out the problem. it was wire insulation on the wires running to the compressor. one was torn and it was grounding out.
Old 07-27-2007, 09:23 PM
bentleymp21's Avatar
i dont know all the technical terms.... but i wonder if you are describing what my ac does. like every 60 seconds , it hisses. yup, thats the best way i can describe it.
is that the problem?
or is this even something i should consider a problem?
Old 07-27-2007, 09:26 PM
aznboi2424's Avatar
if the AC is blowing cold then it should be working fine
Old 07-27-2007, 10:41 PM
aznboi2424
aznboi2424...
thanks. i feel better
do you have any picsof your car from the side. i want to see how the s techs sit with the systemin the trunk. i have a system and its going to get bigger. i dont know if i should do s techs or h&rs.
i would love to see pics..
thanks again
Old 07-28-2007, 09:04 AM
fuzzy02CLS's Avatar
The hissing is normal. It's worse if you have an AEM or Injen CAI.
Old 07-28-2007, 10:13 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Sorta, it could still be low on refrigerant. (especially if it cycles alot)
Hissing is normal
Old 07-28-2007, 12:35 PM
o1s
o1s's Avatar
mine was engaging the clutch every 1 or 2 seconds. on...off...on...off.
SidhuSaaB
05-30-2020 12:40 AM
12vancover
10-16-2015 12:04 PM
Skirmich
10-01-2015 12:59 PM
Matthew Purpura
09-25-2015 06:10 PM
mellsonnj
09-24-2015 04:42 PM
Quick Reply: Odd AC Problems
