This is not good!!!
Concave All Da Way!
This is not good!!!
So this morning the sun came out, i decided to take a look under my hood, check for oil, power steering, antifreeze, etc. Then i pop my spark plug and WTF!!! what do i find...oil in the spark plug chamber. This never happen b4, i change the stock to the Bosch platinum 4 3yrs ago when i got the car and now this happen!? I'm guessin i didnt tighten the spark plug enough cus when i losen it, i didnt use that much force. That mite be the problem or is there a leak sum where, what do u guys think any ideas or help, thanks. I'm in the process or takin all my spark plug out at the moment.
![](http://i759.photobucket.com/albums/xx235/mr2fast2thao/My%20wheels/02102010284.jpg)
![](http://i759.photobucket.com/albums/xx235/mr2fast2thao/My%20wheels/02102010286.jpg)
![](http://i759.photobucket.com/albums/xx235/mr2fast2thao/My%20wheels/02102010289.jpg)
![](http://i759.photobucket.com/albums/xx235/mr2fast2thao/My%20wheels/02102010287.jpg)
![](http://i759.photobucket.com/albums/xx235/mr2fast2thao/My%20wheels/02102010288.jpg)
Concave All Da Way!
its my 01 CLS. about the bosch i guess it all the talk about it 4/5 years ago so thats y i got it. its only the first left plug thats leaking, the rest are fine, what is the correct spark plug i should use?
![](http://i759.photobucket.com/albums/xx235/mr2fast2thao/My%20wheels/leakingoil.jpg)
Concave All Da Way!
thanx. where can i find the NGKs, at my local auto store or do i have to order em? & u sure my valve gasket is also leaking, i look around and no leaks?
Might have been a spill from a sloppy oil change but more likely the seal is shot. Clean it up and see if you get the oil build up again.
If the Bosch plugs have been working ok for this long I'd leave them alone.
OG 3.x^7 rawr
I would change the plugs to NGK and get a valve cover gasket kit with the grommets. Should be about $30 and should have tube seals, top grommets, and valve cover gaskets. When you change it, clean out the intake manifold and thorttle body.
OG 3.x^7 rawr
I don't get why all these people use differen't brand plugs for Honda/Acura.....NGK#6994/IZFR6K-11 is what your suppose to use. Anything else, your on your own.
Honda/Acura: NGK
Toyota: NGK or Denso
VW: NGK from what my VW tech tells me now
Ford: Motorcraft
Chevy: AC Delco
NGK is really the mostly used brand for imports and even some Euro's.
Honda/Acura: NGK
Ford: Motorcraft
Chevy: AC Delco
Concave All Da Way!
back when i got my car i didnt know about NGK spark plugs, all i heard and see is Bosch, even when i walk into pep boys or autozone i see em. well i just finish puttin the new gasket in and what i see is the one that has oil, has a little crack on the seal, thats y it was leakin. sry for got to take pix. imma use the bosch for now cus the rear spark plug is a bitch takin them in and out with so little space, so ill grab sum NGK this weekend and slap em on.
Concave All Da Way!
![Drunk](https://acurazine.com/forums/images/smilies/drunk.gif)
Blown is Best
"DD" Designated Drinker
the deal charges like 150ish i think i asked before i did mine. i was like i think i can handle it myself..... but the back isnt too bad. i got the NGKs love them they last and are recommended. i do believe that in the owners manual and maybe under the hood(not 100% sure) it has the NGK number. but ya the deal will charge an arm and a leg for a simple job. just tough it out
i havent done it personally but I got my mech to change them as part of the 105k. I know you have to take off the intake mani and the valve covers. but by that time, might as well do a valve adjustment, plugs, valve cover seals and thermoblock spacers if not replacing the gaskets.
naw, NGK Lazer Iridiums. Now thats the good stuff.
feel free to ask your local acura dealer how much they are.
put new tube seals in. problem solved
Concave All Da Way!
yea its the spark plug tube seal that has a crack, got all 6 of the tube seal replace and brand new valve cover gasket
dont know y it crap out only at 92k is it common at that mileage?
Pegon95
09-15-2015 01:54 PM
