NOS, CEL and no 2nd->3rd shift
Old Jun 27, 2005 | 04:30 PM
rtatsutani's Avatar
Never had a clean run
Ok, this is the third time this has happened. When using my 75 shot Zex kit, pressure is > 700 or so, and VSA off, my car won't shift out of 2nd gear, SS or gate. After about 10 seconds w/o NOS and driving normally, the car shifts normally once again except for the CEL light stays on for a few minutes. May be related to a too lean condition? Ordering my obd2 harness today so will easily see, but it seems like something's not right. Anyone else running NOS experiencing this? May have to get an aftermarket FPR and fuel pump?
Old Jun 27, 2005 | 04:41 PM
mrsteve's Avatar
This is somewhat normal on our automatic tranny cars that are boosted/sprayed. However I never got a CEL thrown. The car wouldn't shift at all until the revs dropped below 5000 or 5500 rpm (I don't remember which).
On my car it happened whenever I lost traction at the top of first and during the second gear shift with VSA off. If I had traction throughout first and second it always shifted.
Old Jun 27, 2005 | 05:59 PM
typeR's Avatar
it happens to me no boost no nitro..but now much less and not as long now that ive got the oil jet kit...one way to get it out right away is to shift into neutral and back into drive or SS ...it will come out of gear ...im 99.9 that youre cel is unrelated
Old Jun 27, 2005 | 06:32 PM
rtatsutani's Avatar
Thanks guys.
Damn, that sucks. So no real solution huh? I just gotta go to the tracks and take a chance of makin' ass of myself puttin' down the quarter in 2nd gear. I'm gonna order my obd2 this week and read the scan codes and let you know if anything pops up.
Old Jun 27, 2005 | 10:07 PM
quicksilver10101's Avatar
mine does it when ive been beatin on the car alot..i think its just the tranny being the pos that it is
Old Jun 27, 2005 | 10:11 PM
babyblue's Avatar
Sold but not Forgotten...
Got the same issue as well on occasion.. 2nd gear has to drop below 5k before you can shift it manually or swich it to d5 and let off the gas... The car shift into 3rd and then into 4th....
Old Jun 27, 2005 | 10:34 PM
typeR's Avatar
like i said if you go ahead and shit into neutral and back it'll come right out of gear and go into 4th maybe even 5th depending on how fast you go from neutral and back into drive
Old Jun 28, 2005 | 07:17 PM
MtBikR's Avatar
Under spray my car has thrown codes numerous times. I haven't had the problem of shifting but only once. I think it involves throwing a tranny code due to the increase power preventing the tq from locking up. The car also goes into saftey mode with this code and therefore cuts power to the engine immediately. You can use a OBD2 scanner to read the code and clear it or in these cases turn off the car and it will clear itself, unlike some other engine codes.
Old Jun 28, 2005 | 09:40 PM
rezurex's Avatar
drop em like its hot
whenever i couldnt shift out of 2nd it was cuz my tranny died... invest in a tranny cooler, maybe that'll help a little
so you spray off the line?
Old Jun 29, 2005 | 01:38 AM
rtatsutani's Avatar
I used to spray off the line till I had an intake backfire. It burped my entire air intake system off my throttle body, stripped my nitrous nozzle threads in my AEM intake and shredded some of my hood insulation . So needless to say, after that I just spray after 2500 RPMs or so.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
