Nos
Old Jan 21, 2002 | 09:06 AM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
Nos
Does anyone have, or know someone that does...have NOS in their 3.2 CL/TL TYpe S?
ANy pros and cons about putting it in?
Thanx everyone for any input
Old Jan 27, 2002 | 02:52 PM
Nicky Pass's Avatar
Fuct in the hed!
NOS=BREAKAGE
Old Jan 27, 2002 | 03:16 PM
Pull_T's Avatar
Originally posted by Nicky Pass
NOS=BREAKAGE
Wow, that's some great insight.
Of course you have extensive experience with N2O, right?
Old Jan 27, 2002 | 06:34 PM
fastvtecCL's Avatar
fastest time 13.4@107 !!!
i have it
Old Jan 27, 2002 | 08:24 PM
senile32nd's Avatar
Apple tech needing a h22a
get a jacobs electric nos controler and use common sence and you ll be fine
Old Jan 30, 2002 | 08:45 PM
Nitin's Avatar
But I just got here
Re: Nos
Honestly, I'd say pros: none, cons: catastrophic engine failure. Seriously, you should have some really good reasons for getting NOS other then just the fact that you saw them using it in The Fast and the Furious or something and think it's cool. It's really only for the guys who take it to the track all the time, not at all for just normal driving. I couldn't even imagine trying to use NOS while driving even on a highway let alone a main road.
Old Jan 30, 2002 | 08:56 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I never floored past 90 HW what so ever that just a 3rd to 4th shift...
Whay you need NOS????
Old Feb 5, 2002 | 12:58 AM
dcsquirm88's Avatar
I have it too
Old Feb 5, 2002 | 09:02 AM
CLUofI's Avatar
337
(not hijaking) damn 2 infinity perfects those look like 12's. What amp are you running? I have one 12 with a 400 watt alpine:thumbsdn:
Old Feb 5, 2002 | 01:27 PM
dcsquirm88's Avatar
Yeah two 12's being pushed by a rockford fosgate 800.2 punch amp.
Old Feb 5, 2002 | 01:32 PM
dcsquirm88's Avatar
Re: Re: Nos
If you don't know anything about a nitrous system you shouldn't give advice on it. They are no cons if used corretcly. Pros take 2 seconds off your 1/4 mile times.
Old Feb 13, 2002 | 04:59 PM
Pull_T's Avatar
Re: Re: Nos
I can't imagine you've ever driven a car with gas...
Old Feb 14, 2002 | 09:35 AM
digitalgm's Avatar
"v1 saved my ass ......."
I think that would be a fair assumption. .... basically, disregard all the mis information propoganda that F&TF put out because they were funded by NOS (the company).
AdamR
Old Feb 14, 2002 | 12:20 PM
99CL2.3's Avatar
Re: Re: Re: Nos
dc, thank you for clarifying that. People, please don't offer opinions on N20 unless you are familiar with it. Nitrous, if used correctly can be used in ANY car. It simply makes the engine run more efficiently. That being said, don't try putting a pro shot fogger on your four banger with two ports for each cylinder.
I used to run a Sneaky Pete on my first car, a Subaru sedan with 1.8L motor. I would beat the crap out of the early ricers and actually made a fair amount of money with it until the trans went. If you do decide to run nitrous, I wouldn't recommend more than a 75-100 shot unless you have a built motor. And only shoot at WOT.
Old Feb 14, 2002 | 02:40 PM
senile32nd's Avatar
WOT ????
Old Feb 14, 2002 | 02:46 PM
dcsquirm88's Avatar
Wide Open Throttle
Old Feb 14, 2002 | 02:56 PM
digitalgm's Avatar
wide open throttle .... floored
late
Old Feb 14, 2002 | 03:11 PM
99CL2.3's Avatar
Wide open throttle. You'll do serious damage to your motor otherwise.
Old Feb 14, 2002 | 03:54 PM
senile32nd's Avatar
ok i know you have to be wot i jsut didnt know the acronym that is all
yeah if you dont youll run the chance of running way to lean and you know hwat happens there
of course you can run gas nozzles next to the nitrous and then you can run huge shots of nitous
Old Feb 14, 2002 | 05:20 PM
dcsquirm88's Avatar
Just get a zex kit it only shoots nitrous when your at WOT. It comes with a computer that regualtes the shot only to come at WOT and your air fuel mixture according to bottle pressure so you never run to rich or to lean.
Old Feb 17, 2002 | 12:56 AM
SleeperCL's Avatar
http://www.acura-cl.com/forums/showt...threadid=52032
Old Feb 17, 2002 | 07:17 PM
Scorpius's Avatar
A retarded monkey can install notrous...
Old Feb 17, 2002 | 10:27 PM
Chaptorial's Avatar
Wow, i think you just reserved your spot it hell (if it wasn't already done so).
Old Feb 19, 2002 | 04:45 PM
skids's Avatar
You guys w/ nos what did your car do at the track if you've taken it?
Old Feb 19, 2002 | 09:48 PM
Nicky Pass's Avatar
Fuct in the hed!
Actually......MR. MUSTANG, I've own a couple of sports cars, one of which was a real cobra (93), and it ran 12.5 @ 109.
(B 303 cam, 75mm TB, 73 Bullit mass air, aluminum drive shaft, 3.73 gear, MSD ignition/electical system, autometer shift light, Steeda upper and lower control arms, BFG Dragradials, Intake spacer, Motorsport 9mm wires, BBK fender mount CAI..........)
I know my shit when it comes to cars......especially STANGS. A friend of mine had an 89 LX and he sprayed conservativly........BANG......blown head gasket. No one I know can "control" NOS usage.....they spray whenever they can. I don't know anyone that has NOS amd hasn't had some sort of NOS related problem.
Old Feb 20, 2002 | 12:25 AM
dcsquirm88's Avatar
Well then let me be the first person you know that uses nitrous and hasn't had a single problem.
Haven't taken my car to a track so I couldn't tell you skids.
Old Feb 20, 2002 | 09:37 AM
Pull_T's Avatar
I have a freind that blew a piston land in his 90 LX while running n/a with only 290 rwhp, so that must mean N/A=BREAKAGE, right...afterall, my friend had it happen to him.
Anyways, I have a "real" Cobra as well, not sure what that meant...
Old Feb 20, 2002 | 03:32 PM
mat347's Avatar
NOS doesnt cause the problems. Its the tuning that your friends must NOT have done. When a motor is tuned and capable of handling the extra power it will run w/o ANY problems!
Timing, plugs, and A/F ratio is just the beginning. You must also make sure the fuel/cooling systems can handle the extra load as well. Not to mention the different ring gaps and bearing tolerances that are needed for a really big shot.
Old Feb 20, 2002 | 04:15 PM
99CL2.3's Avatar
Amen, brother. You can't put a pro shot fogger on a stock motor and blame your milkshake on the nitrous. Although I've always wanted to try that.
Old Feb 20, 2002 | 05:02 PM
Pull_T's Avatar
Old Feb 20, 2002 | 09:41 PM
Nicky Pass's Avatar
Fuct in the hed!
NOS is to unpredictable, I mean there are too many variables such as, Bottle Temp, Backfires, and how much to use!!!!
Old Feb 20, 2002 | 10:46 PM
dcsquirm88's Avatar
Its really not that hard to use at all. If you educated yourself a little about nitrous and the different systems that are available you would see that!!!!
I wish you would drop it allready its getting old
Old Feb 21, 2002 | 01:31 AM
moforose3.0's Avatar
What can I get ya?
Old Feb 21, 2002 | 11:43 AM
senile32nd's Avatar
Hey YOU know what GROW A FREACKING SACK MAN ITS JSUT A MOTOR IF YOU BLOW IT UP GET A JDM MOTOR AND THROW IT IN THERE WUSSY
Old Feb 21, 2002 | 11:59 AM
Pull_T's Avatar
Old Feb 21, 2002 | 12:21 PM
senile32nd's Avatar
i know i was using caps i was yellin gat the wussy lol
trev0006
Sep 19, 2005 05:10 PM
187_FAQ
Feb 1, 2005 07:39 PM
cuhrupt
Dec 26, 2004 07:57 PM
Mike
Jul 7, 2004 04:07 PM
