Is this normal?
Old May 28, 2002 | 07:36 PM
liquid_x's Avatar
Is this normal?
When I try to connect one of the battery terminals (i forget whether it was positive or negative) is it supposed to spark? To the best of my knowledge that isn't supposed to happen right.
Old May 28, 2002 | 07:46 PM
4pumpedCL's Avatar
Honkey
Mine sparks too. You're not alone.
Old May 28, 2002 | 07:48 PM
D73's Avatar
D73
Curiosity Killed The CL-S
Yeah, it happens. It happens all the time on any electrical device where there's an initial physical connection (eg a light switch). Just that most of the time, the spark is so tiny that human eyes don't see it.
If memory serves, what you're seeing is that little split second where you have just initiated contact, and all that current is flowing thru a very very tiny area. This creates a very large buildup of heat in that tiny cross section, and hence you see sparks.
Think of it this way. Let's say you have a garden hose and you clamp your hands on the outlet so that no water goes through. If you were to open your hands very slowly, you see a moment where the water just sprays out due to high water pressure and small outlet. Then as you allow the outlet to get larger by relaxing your hands, the water doesn't spray out as much.
Not a very good analogy but the best I can come up with now.
Old May 28, 2002 | 08:16 PM
Shawn S's Avatar
Of course its going to spark, you’re completing the circuit.
It will happen weather it’s the Positive or Negative terminal.
Shawn S
Old May 28, 2002 | 08:18 PM
liquid_x's Avatar
well it kinda is a big ass spark though but i guess everything is fine
Old May 28, 2002 | 10:09 PM
D73's Avatar
D73
You need to worry when it sparks one big one, you smell a burning smell, and then your car doesn't start anymore...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rockyboy
Oct 2, 2015 10:45 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
