Nitrous On A 2003 Cl-s6 & what parts needed
#41
Originally Posted by fuzzy02CLS
You are misinformed. The ZEX kit has a little fuel management box you wire to the system. It provides enough fuel adjustment. There are no settings it's all automatic.
All you need are some colder plugs.
The ZEX kit is a complete system, see post above.
#42
Originally Posted by JDM96specCTR
yessir, my friend hit his stock internal k20a2 with 150 shot numerous times and never blew up..
#43
Originally Posted by cl8trr
for a 6k dollar swap thats not cool,its a stock 13 sec block as it stands..but to each his own.
#47
Caffenine Addict
Fuzzy. Do you know the correct size plugs we need? Specifically the ZEXs brand, but if you recommend something else feel free to throw it out there.
My nitrous kit is slowly piecing its self together. I got a great deal on a used Zexs kit with remote bottle opener, bottle warmer and a nitrous gauge. Im probably going to order the dual pod for my gauges as a temp thing. Im not really sure if im going to like them there or not. May have to fiberglass something to my liking. Also ive scouted out an a/f guage on ebay.
I may be wrong but I feel as a small 55-75 shot with not require fuel management. maybe down the road ill toss a Apexi Neo in there for tuning reason but as of now I think I will be good. As soon as my toys get here Im going to mount up the bottle and run the lines. I wont start spraying intill I get those colder plugs in there.
#48
EVERYTHING IS FOR SALE!
I just asked a zex distributer what cold plugs I would need and told him my vehicle and he said that they dont know if cold plugs would be the best plug for my application. Im looking at the kit #82011.
But If fuzzy02CLS is saying we need them, then we need them.
What plugs did you guys purchase?
#49
I'm not sure which ones were used I'd have to find that. They were direct from ZEX though.
I'm not certain you really need them, but all the info I searched out said it was better to run a slightly colder plug.
FYI the CT charger also needs colder plugs. So it does make sense.
#53
82003-6 hyperformance from zex. they run about $40.00 for all 6. car runs fine with them without the nitrous and I dont really know if they are colder than regular plugs,it says on the site that they are specifically designed for nos applications but they do have a triple copper center strap design for better heat dissipation. anyways I could not run at the track because I need a nomex fire retardant jacket when running nitrous?? stupid rule. time to go buy a jacket..
#54
Caffenine Addict
#55
If a shop did it how much was it?
#57
Caffenine Addict
Originally Posted by Cocoa
At first I went with the Zex plugs. Then I changed over to the NGK's one degree colder than stock (6). Use 100-116 octane race gas only. And with my 3.0 I had bigger injectors, but with the J35 I am using the walbro fuel pump. This is on a wet kit btw.
#58
Originally Posted by Tweek
Seems like your the Nitrous Guru. Got a suggestions for us dry users? Also how do you mix up your race gas?
#59
2600lb CL
To add to this, stock has the heat range of (6), so one degree colder would have the number (7) in it.
EX: PZFR7E-11 (NGK)
The first number is what you want to pay attention to.
For those of you that can't find race gas. You can go to your local hardware store and pick up Toluene, which has an octane rating of 116.
#61
Since you installed it yourself, was it easy to you?
#62
Caffenine Addict
I guess I could toss this in this thread, hope someone has the answer. Im waiting for my A/F gauge to show up. When I install it which wire on the 02 sensor do I tap onto?
#63
I am gonna try all three shot options with 75 being the largest, I will have timeslips and post them friday maybe sat.(thurs. if time allows) low 13s?WOW that sounds like a lot to ask 4 though, I am pretty consistent with my manual with my passes within 1/10sec. of each other,of course times vary with temperature. car sucks ass in the heat
#64
Caffenine Addict
Woo. Early Christmas present to myself
![](http://i23.photobucket.com/albums/b385/sstrawsb/100_7229.jpg)
Im not putting it in for probably after Christmas since the car is in the shop till Monday. Have to get the rear lower control arm replaced. The only thing holding me back from doing it is one bolt. It whooped my butt. Even one shop couldnt get it off. They were pretty pathetic tho.
Back onto topic. The bottle only came with a 55hp jet. Im ordering a few other jets with a new nozzle also. Ill keep you all posted
saberlove
03-11-2021 09:29 AM
handsom-hustla
11-13-2015 05:04 PM
