New rotors and pads r in *pics*
'Cooter
haven't really tested the brakes yet cuz im trying to break em in nice and slow...initially, tho, they're a lil more grippy than the upgraded TLS pads
here r the rotors...
![](http://images2.fotki.com/v20/photos/4/43461/223706/13-vi.jpg)
![](http://images2.fotki.com/v20/photos/4/43461/223706/14-vi.jpg)
![](http://images2.fotki.com/v20/photos/4/43461/223706/15-vi.jpg)
![](http://images2.fotki.com/v20/photos/4/43461/223706/19-vi.jpg)
![](http://images2.fotki.com/v20/photos/4/43461/223706/17-vi.jpg)
![](http://images2.fotki.com/v20/photos/4/43461/223706/18-vi.jpg)
![](http://images2.fotki.com/v21/photos/4/43461/223706/21-vi.jpg)
'Cooter
Originally posted by eclipse23
Congrats, looks good.
Suggestion: Paint your calipers black.
Looks GREAT man.
What’s the outside diameter of those things?
I was thinking about getting in on the “group buy”, but I’m pretty sure they wouldn’t fit inside of my 16” TL rims that my snows are mounted on.
Shawn S
Shawn S
'Cooter
Originally posted by ST2000
I want I want, where did you get the rotors? fronts and rears? How much?
www.eurobraketech.com
Administrator Alumnus
Originally posted by Scooter
all 4 rotors cost about $430, which includes shipping ($190 for the fronts, $240 for the rears)
How much for the install???
Doin' da crack shuffle
yo, just realized something...my rotors r backwards, ren't they???
I was thinking the same thing! It looks like they are.
about the same as stock...roughly 12in
yer rims will b fine
Maybe I’ll bring along one of my TL rims for a “test fit” next time we get together.
Shawn S
PS…. What do you mean backwards? Are the left & right front swapped ?
MP90 uninstalled
I have read in other posts and places that some of the aftermarket rotors are simply USDM rotors with slots and holes drilled in them. ture or not? I had a 95' accord with a bunch of bolt-ons, ZR rubber, and the four wheel power stop rotors and axis metal master pads.
while there was the noticable increase in the braking feel desired, I still warpped the crap out of the front rotors about every ten months. I will be honest though and tell you that I was living in Birmingham, AL and would RACE to school every day hitting 100 MPH and hitting the brakes down to 60MPH repeatedly running up and down I65.
I enjoyed my power stop rotors as I was warping stock accord rotors every three two to three months.
However, I guess my question is do you know of or have any solid evidence that these rotors are made of a higher grade steel/ore. how much more heat disapation does sloting a stock diameter rotor offer. Is the heat soak capacity of the rotors you have higher than the capacity of the stock rotors. Most importantly, I am sure you have read the thread about warped stock rotors currently on the car talk board, do you think these rotors will not warp under very normal to infrequent sporty driving conditions on my/your CLS?
P.S. I think your rotors may be backwars as well. Althogh they look great.
for what its worth,
Jim
Shawn S,
what are you refering to when you say a $1400 dollar purchase. Scooter said all four rotors only cost $430?
for what its worth,
Jim
Shawn S,
'Cooter
after a couple convo's with people, the pattern direction doesn't matter...the ability for heat to dissipate is the same either way
also wanted to thank the service crew once again at PAA for doing such a wonderful job with my service visit and follow-up convo's with Pete and Jens this afternoon on a couple questions...guys, keep up the superb work u do always
Originally posted by jproy
Shawn S,
Shawn S,
There’s a group buy going on right now for ROTORS, CALIPERS, Pads & STN STL Brake Lines that’s like 1,400 bucks.
Shawn S
'Cooter
Originally posted by Shawn S
Scooter just got ROTORS.
Shawn S
Shawn S
You know after a few hours of scratching my head i found a catalog from Brembo that shows the rotor slots/holes going in both directions .I cannot imagine this making any difference and when I installed it looked a bit weird too but the boxes were marked as to which way they were supposed to be mounted so that is what I went with .Jens
Blackbird baby..
What made you decide to go with the drilled & slotted over the just slotted? Most everything I've read about the x-drilled says not to do it--like they introduce metal fatigue points in the rotors and could cause "catastrophic" brake failure during high-speed braking.. But primarily that they don't really contribute to brake cooling/gas dispersion. Because that's the main reason for slotting--to get the hot gases away from the brake surface, essentially by wiping them away via the slots.
Tanks.
Tanks.
'Cooter
Shawn S,
Why do you want to put new calipers on a stock diameter rotor?
thanks,
Jim
Shawn S,
thanks,
Jim
'Cooter
Tanks.
Tanks.
and if nothing else, the cd's r jus fo decorashion, that's all
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
MP90 uninstalled
Shawn S,
I was not aware someone was making a 4-piston caliper for our stock diameter rotors. Wouldn't you still have similar problems with warping even with a 4-piston caliper on a rotor of the same diminsions as stock. Exceeding heat soak capacity of given volume of alloy. another question, At $1400 for rotors pads and calipers why wouldnt you just get the Rotora brake kit.
thanks for your time,
Jim
Jim
Shawn S,
Shawn S,
I was referring to THIS thread: http://www.acura-cl.com/forums/showt...threadid=98574
Shawn S
'Cooter
Scooter,
Another thing I just though of.
You had better check your SPARE to see if it still fits. Ours is a 16” steel wheel…NO ???
Shawn S
Scooter,
Shawn S
Location: Somewhere between here and there, yet neither.
The CL has 1 piston calipers stock, the Legend has a 2 piston version and for 4 pistons, we need to upgrade to Brembos or the Rotoras. I have read the argument many times for x-drilled v. slotted v. dimpled v. every combination of the former. I have had x-drills on my cars for the past 10 years. I hear they can crack...but if you listen to who tells you these things, its usually the dumbasses that track their car when the brakes specifically say not for track use!! The Brembos have been tracked tested...they never cracked, although they do eat up the rotor with the track only pads.
Just a thought but, I bet its not so much the x-drilling as the fact that the stock calipers are only 1-piston which would mean that only one point of the pad is being pushed against the rotor v. 2 piston v. 4 piston v. x-pistons.
