New grille..pics..
New grille..pics..
Alright well just got done with my new grille.
I decided to leave the trim around the grille chrome for now, but when i do my headlights then i might paint the trim black too.
The car is filthy just wanted to show off my new project
![](http://i3.photobucket.com/albums/y57/hay112/grille1.jpg)
![](http://i3.photobucket.com/albums/y57/hay112/grille2.jpg)
That looks really nice. I actually did the same thing for mines, only I don't have the emblem attached to the front. How did you attach the emblem? BTW either I'm seeing things or does it look like someone was testing it's flexibility-it's noticeable on the second pic, on the right-hand corner. As if someone pushed it with their thumb or something...
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Here's the material i used:
http://www.mcmaster.com/
1 EA 9232T131 - Aluminum Perforated $27.61 EA $27.61 today
Sheet 36" X 40", .1875" Hole
Dia, 51% Open Area, .032" Thk
yeah i just noticed that in the right corner too, hmm wonder what i did, as far as mounting the "A" I just cut two small holes behind the "A" and mounted in it's stock location and screwed it in as it was before. If i can do this anyone can.
I actually painted it with high temp paint, i should have used a primer but i didn't think about it till afterwards, plus i sprayed on about 6 layers so i should be good.
thanks jandj2204
thanks jandj2204
GEEZER
Meh...![Yawn](https://acurazine.com/forums/images/smilies/yawn.gif)
But if you like it...
COOL GRILLE
Looks like you could of used a milar bra for the stone chips though
Black shows everything I own 2 black cars.
Originally Posted by juruki
I cant find the grilles in mcmaster... Any help?
Originally Posted by chevyjase
COOL GRILLE
GEEZER
Sweet car, but it is begging for a drop.
Originally Posted by n1976jmk
where did you get the wheels done???
Hey Hay I like it. I did mine too.What i did different was remove that inner plastic that housed the other chrome piece that is no longer there.It took a lot of time and precision but it really came out nice. just an idea.......
Hey gbone88, How did you remove that inner black piece where the emblem originally screws into? I did my grille as well, also with super precision. My old grille was broken so I used it as a blue print for the new one that's on the way. I used the chrome outline for the job. It took me a while but it's not going to move a centimeter. What I did was, and unless you guys have a spare grille don't try it because you're basically ruining it. I took the chrome piece after I had the shape cut out and broke off all screw sockets and clips on it. I then aligned the cut-out directly on top of it and made sure that it was symmetrical on all sides. Then I carefully cut around all the sockets and holes that I broke off. Now all I have to do is wait for the new one to arrive and it should fit precisely. It was a long process but I just wanted for it to look clean.
i took the grille off about 2 months after i did it because of all the nicks and scratches...I just haven't had time to redo it, i wanna make sure i prep it right this time...
as for the wheels they're actaully chrome
Don't Mess With Texas
hmmm your A on the front isnt straight...and your 3.2CLS is low on the back and the ACURA is high and closer together than its supposed to be.....i thnk you should run a carfax...may have been hit from the rear.
yeah it was hit from the back
edit:
you augta just take that shit off it looks 10x better without the ACURA trunk looks so much less cluttered and way phatter
Originally Posted by cltypeSLOW
if you wanna take your ACURA off and put it back on how its supposed to let me know...cause i measured exactly where the letters were when i took them off. i can let you know. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
edit:
edit:
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
