new ballast/ignitor
Old Jan 10, 2009 | 08:46 PM
Scepter's Avatar
new ballast/ignitor
My car is pushing 140k miles and I'm sure that the original ballast/ignitor from Acura is still installed (nothing wrong I just wanna prevent future problems).
I was wondering if replacing the ballast/ignitor would increase the light output and make the HIDs 'brighter'?
If so, is there any company that makes a replacement I could buy instead of having Acura charge me a couple hundred per ballast/ignitor.
Old Jan 10, 2009 | 09:18 PM
Allout's Avatar
Blown is Best
I doubt a new unit would increase output. The bulbs will degrade over time and would have the biggest impact on output. As a preventative measure, you could always apply some silicone to the balast to seal the area where the wires exit the ballast body.
Old Jan 10, 2009 | 09:33 PM
CL6's Avatar
CL6
My only car is a Bus
Why take a shortcut with brakes, tires, pads, wipers, or lights? OEM is OEM for a reason and with 140k on them now I'd say you did fine.
Old Jan 10, 2009 | 11:12 PM
aznboi2424's Avatar
Replacing the ballast/ignitor wont make much if any difference. you would be better off replacing the bulbs. They get dimmer with time and they arent as expensive as ballasts/ignitors.
Old Jan 14, 2009 | 11:13 PM
HIDStuff's Avatar
Yeah, you don't need to replace the ballasts and ignitors until you have a parts failure, meaning no light at all. Also, stick to 4300K bulbs when you replace them. As the K value increases, they aren't as bright. Even blue bulbs at 6000K seem dim, especially in the rain. There's definitely a tradeoff between bling and bright. Just my 2 cents.
ryan5003
Feb 6, 2014 11:21 PM
Tannon
Mar 20, 2013 04:56 PM
PMGCamaro
Oct 6, 2007 12:59 PM
thamind
Jul 28, 2007 01:13 PM
vicsanity
Dec 1, 2006 12:25 PM
