Neuspeed Strut Bar... Need Help
I tried to put it on and the holes wont line up. Like one side will go on and the other wont. How do I fix it? Do i have to loosen the third nut? Someone please help.
Originally posted by jrod178:
<STRONG>I tried to put it on and the holes wont line up. Like one side will go on and the other wont. How do I fix it? Do i have to loosen the third nut? Someone please help.</STRONG>
If you are talking about the front bar, you might want to try loosening the "stock" (factory) bar first. If you just loosen-up the strut tower nuts, you should be able to just slip the Neuspeed bar on.
When I got mine, I did notice that it almost looked like mine wasn't going to fit -- I had just received the bar and was holding it over the strut tower studs (with nuts on).
Once I loosened the factory bar and removed the 2 nuts (on each side), the bar slipped on.
If you already did this, and are still having problems, I'm sorry for wasting your time...
[ 08-02-2001: Message edited by: EricL ]
Originally posted by thholr:
<STRONG>Mine fit perfectly , but there are people that had to jack their car up to make it fit. Try that and it should work just fine</STRONG>
I thought Jens said that this was not such a great idea... (yes/no)?
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
