Negative Chamber ??????????????
Old Feb 21, 2001 | 02:10 AM
StypeCL's Avatar
Other than excessive tire wear, what could go wrong with the suspension while running too much negative chamber?
01 CL-S Satin Silver
Eibachs, brushed aluminum dash kit, 5%tint all round, spoiler
Old Feb 21, 2001 | 12:47 PM
Wyle E. Coyote's Avatar
ACME sucks!
<font face="Verdana, Arial" size="2">Originally posted by StypeCL:
</font>
I'm sure you meant to say "camber". Other than severe tire wear, too much negative camber can also cause handling problems on wet surfaces.
Guys, please correct me if I'm wrong.
2001 Acura 3.2CL Type-S
Satin Silver/Ebony
No Navi
35% tint/Wheel locks/Splash guards/PIAA 19169 bulbs/K&N 33-2178 air filter/Mobil-1 5W-30 oil & filter/One scratched rim
Old Feb 22, 2001 | 02:09 AM
DtEW's Avatar
<font face="Verdana, Arial" size="2">Originally posted by MikeN:
I'm sure you meant to say "camber". Other than severe tire wear, too much negative camber can also cause handling problems on wet surfaces.</font>
Absolutely right. Too much negative camber will also:
1. worsen the car's turn-in response.
2. increase the car's braking distance.
It's too bad that most cars aren't adjustable for caster. Now there's a hell of a tuning tool!
051/LP/SR/LD/HH
Old Feb 23, 2001 | 12:42 AM
Jens H.'s Avatar
retired
It will negatively impact the cars acceleration since the weight of the car is not distributed evenly over the tire patch possibly causing excessive tire slip on take off.Best bet here is to correct the camber problem.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Feb 25, 2020 09:57 AM
0opie
Sep 22, 2015 04:15 PM
ctlx23
Sep 13, 2015 09:55 AM
Phambam12
Sep 6, 2015 06:57 PM
