need a wire diagram from the service manual
hey all i need to find the wires colors to the sensor that comes outta the side of the catalytic converter that plugs into the cars wiring its has a yellow jacket over the 4 wires 2 blacks, i think a green, and a white. when i was taking my exhaust down i didnt unplug the connector and the wires ripped right outta the socket. i can put the wires back into the socket but im not sure what wires go in what holes? im sure theres a diagram that shows the wire colors from the sensor and the wire colors from the car.
p.s its an 02 TLS and the wires from the car are not the same color as the wires coming from the sensor. im guessing that this sensor is gonna be the same in the CL
Wire colors are not in service manual.
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
1 Post
Just go to your public library and look up electrical wiring for Acura and your year CLS in the Mitchell Automotive manual (it's huge). You will find ALL the wiring and colors of wire you need in that manual for the o2's. That's what I did when I was doing some wiring! Good luck.
Found the wiring diagram with wire colors
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
![](http://www.frankiesilver.com/Music/o2s-wiring.jpg)
I hope this helps, because it took some major digging to find the wire colors. Nothing is where you would think it would be. Have a good day!
