Need A New Clutch!!
Lives On BOOST
Need A New Clutch!!
The comptech friction disk I ordered off a member here is no good! When the mechanics tried putting it in with the Ur flywheel and oem pressure plate it didn't work. So now Im stuck and I don't know what to do with the clutch, and I need one that fits with the UR flywheel! I NEED HELP ASAP
Lives On BOOST
Well, found out today that there is no other clutch that is compatible w/ the ur flywheel, and the comptech piece is just no good. Ima try to contact the guys at comptech and see if the friction disk was made to go w/ their flywheel b/c i dont think it was made to go w/ the oem one (dual mass)?
Lives On BOOST
hey jeff, found a site that has a pic of the flywheel:
http://www.customcarscentral.com/unr...l--01-03-.html
Blown is Best
If that's the actual CL Flywheel, you're right. There's not much room. It's hard to gauge the depth but it kind of looks shallow. It's also missing the center section that has the pilot bearing.
Lives On BOOST
Originally Posted by Accord_V6_400m
Interesting, call up Unorthodox Racing ASAP and ask them, you can also try calling Clutch-masters.
4drs just wanna have fun!
Originally Posted by krisdlm
yea, i tried. UR tech is useless, and it seems that the only thing that will work is the oem friction disk
Im sure the space will allow it but now you wont have a sprung clutch or a dampened flywheel, hopefully your OEM crank pulley is still on your car. Either way try giving a call and ask them about it, or try returning the UR flywheel.
Cool, just checking
Guess your going to have to go with a solid hub clutch disc or return the flywheel
Lives On BOOST
New engine?
solid hub refers to the lack of torsional springs in the clutch disk.
Blown is Best
It blows me away that they would design this to only work with an unsprung hub friction disk. Why go through the effort of designing a flywheel and create so many limitations around it.
Lives On BOOST
im going to try to talk to ur again and get something out of them. jeff is right though, why even put a flywheel like this into production?
Lives On BOOST
so i talked to ur again and they say the same shit. oh, well, this flywheel hasnt have enough production to ever run into something like this and we can look into it further but I guess your only bet would be w/ a non-sprung hub. I told them about the comptech friction disk and they didnt have any answers. My car is about ready to go and im not sure if i want to go through any more trouble of taking shit out and putting shit back so i just might keep the flywheel on. that wouldnt be a problem would it?
if they dont make a very strong disk(backing plate and contact material) you will have trouble and the clutch may only last you only a couple of months of normal use, send your flywheel to and have it notched and you can use the comptech disk and have a lighter flywheel.
Lives On BOOST
I got you covered Allout
Translation:
WARNING: ALLout is not responsible for any damages or loss that may occur from this machining process, procede at your own risk
I would be very cautious on machining out the UR Flywheel to accomodate the sprung hub on the Comptech friction disk.
Blown is Best
Translation:
Translation:
LOL - I've seen what damage an exploding flywheel can cause. I'm probably overly cautious but...
Your Oe Flywheel Buddy!
hey jeff, i dont know if you read my other thread but what should I do about the crank sensor? Shop says its fucked!?
dont notch the aftermarket flywheel,notch the original on the sides,not the center! clutch- masters will do it for you, you will still be able to use your comptech disk and lighten your flywheel a little, may not be much but its something! nick didnt marcus have that done to his over at c-m
I don't know if its me but I don't remember who Marcus is
