Need More Boost
Old May 16, 2005 | 12:03 PM
Chemmech's Avatar
Question Need More Boost
Where can I get a pulley for the S/C'er to get past 10 Psi?
Old May 16, 2005 | 12:10 PM
JaredGMS's Avatar
Meat stick
Old May 16, 2005 | 12:13 PM
Smitty's Avatar
Blower is spinning twice as fast now....
You can not get more boost out of it.
Old May 16, 2005 | 12:23 PM
ThinJim's Avatar
I think I remember sgmotoring cutting another pulley for more boost. Never saw anything else on that effort though. Where's he at? It wasn't that long ago.
Old May 16, 2005 | 12:34 PM
mclarenf3387's Avatar
I thought the blower was maxed at 10 PSI?
Old May 16, 2005 | 03:15 PM
mrsteve's Avatar
The internal blower speed should not exceed 16,000 rpm. That works out to be around 10psi. After that you run the risk of the blower's internals hitting each other or throwing a bearing. 10psi is all you'll get safely from the 62 series blower. Time to step up to a MP90 where you'll get 15psi. A smaller pulley can be made though...although I wouldn't suggest it. Contact www.pulleyboys.com
Old May 17, 2005 | 10:20 AM
Smitty's Avatar
have fun trying to fit the MP90 under the hood.
Old May 17, 2005 | 12:59 PM
mrsteve's Avatar
The physical size of the two blowers are not that different although the MP90 is considerably wider than the MP62 (by 12"):
Old May 17, 2005 | 01:53 PM
ThinJim's Avatar
Originally Posted by mrsteve
The physical size of the two blowers are not that different although the MP90 is considerably wider than the MP62 (by 12''):
Not sure, but they might be MM not ''(inches)
Old May 17, 2005 | 02:16 PM
NiteQwill's Avatar
Adventurist.
12 inches would be sure a hell of a lot
Old May 17, 2005 | 02:58 PM
mrsteve's Avatar
You are correct. That is definitely MM.
In that case it could definitely be made to fit.
Old May 17, 2005 | 02:59 PM
allmotor_2000's Avatar
How on earth are you running 10psi right now on 91-octane?!?! I have to retard timing at 6psi.... we do have the same engine, right?
I think its the difference in air-flow.... I don't think the S/C flows the same amount of air as a turbo.
Old May 17, 2005 | 03:31 PM
mrsteve's Avatar
Based on my calculations, with the following parameters (which is what is provided with Scalbert's IC kit):
7" Crank pulley
3.275" Alternator pulley
3.3" SC Shaft pulley
The blower spins at the following speeds:
I'm no math wiz so these calculations could be completely off... but I based this off a calculator for the RSX kit which also uses the MP62 blower.
Old May 17, 2005 | 04:24 PM
mrsteve's Avatar
I tweaked it a little bit so it should be reading accurately now. Basically with Scalbert's combination of pulleys you are pretty damn close to the max rpm that Eaton's graphs hit for the MP62. Notice they all stop at 16,000 rpm
Delta P: Pressure Difference
Volumetric efficiency: Efficiency with which engine can move air in and out of combustion chamber. 100% = as much mix goes in as volume of combustion chamber is.
Old May 17, 2005 | 05:31 PM
mrsteve's Avatar
Calculations are wrong. I forgot one aspect of the formula required. I'll update it later...
Old May 18, 2005 | 08:44 AM
Smitty's Avatar
Payne Technology in Florida.... I believe that is where we got the pulley made for the Supercharger jack shaft.
Old May 18, 2005 | 10:10 AM
mrsteve's Avatar
I thought they were in Michigan, not Florida.
Old May 18, 2005 | 12:11 PM
Smitty's Avatar
PM Scalbert or Modaddict...
Essarack sent me his pulley... I sent it off to Steve who in turn sent it off to payne tech.
they have the specs on the pulley.. I am sure they could help you..
Old May 18, 2005 | 01:16 PM
mattg's Avatar
the fact that you're wanting more boost makes me wonder how well your car is running.
you should have at least 350 whp, right?
have you dyno'd your car lately to see what it's putting down?
Old May 18, 2005 | 04:23 PM
Smitty's Avatar
spin that supercharger more than 10psi I wanna see what happens..
Old May 18, 2005 | 05:08 PM
sgmotoring's Avatar
Bleed Honda Blue
Don't need to wait. I am running over 10psi .
Old May 18, 2005 | 07:33 PM
Smitty's Avatar
https://acurazine.com/forums/showthread.php?t=167841
oh we are all aware of that... you ALOT of luck...
Old May 18, 2005 | 07:56 PM
mrsteve's Avatar
What is the diameter of your custom pulley?
Old May 18, 2005 | 08:21 PM
SCTL-SS's Avatar
13.68 @ 102.56
I have the Payn tech pulley...and I live in FL. maybe that's were the confusion came from. The pulley is certainly 10 Lbs.
Sorry for not having any more updates on the car. Maybe I can pick it up tomorrow or Friday (I'm not holding my breath).
Old May 18, 2005 | 08:27 PM
mrsteve's Avatar
Do you know the diameter of the Payn tech pulley?
Old May 18, 2005 | 10:08 PM
ThinJim's Avatar
Old May 18, 2005 | 10:21 PM
mrsteve's Avatar
You need a build progress update thread. Kthxbye
Old May 18, 2005 | 10:52 PM
mattg's Avatar
holy zero clearance piston, batman!
Old May 18, 2005 | 11:44 PM
Allout's Avatar
Blown is Best
Those are some serious valve reliefs
Old May 19, 2005 | 07:11 AM
ThinJim's Avatar
Old May 19, 2005 | 08:42 PM
ThinJim's Avatar
Old May 20, 2005 | 06:40 AM
SCTL-SS's Avatar
13.68 @ 102.56
No I don't, but I believe the dimensions are listed probably on a previous post. Do a search under "Max" boost pulley. If that doesn't work you can contact Payn Tech.
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
Sep 17, 2015 08:57 PM
Sep 14, 2015 10:48 AM
