Need Help Understanding. (84-1 Sensor Logic Failure)
Old Mar 2, 2012 | 07:39 PM
Jah01CLTypeS's Avatar
WhiteChocolateTypeS
Exclamation Need Help Understanding. (84-1 Sensor Logic Failure)
Having a small problem with the CL-S.
Traction Light is on...code read 84-1 Sensor Logic Failure.
I found the solution only problem is I can't do perform the reset and need a little help. Here is a actual problem and solution...but can someone break it down for me?
http://www.justanswer.com/acura/39xp...rol-light.html
The main thing I need to know is this though: Is it safe for me to drive cross country with my VSA not working and my Traction Control indicator lit? If so, then great...if not...then please advise.
Old Mar 2, 2012 | 07:51 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
You can try a basic ecu reset and see if that does anything.
Have you tryeid to clear the DTC's ?
Don't know much about those codes.
Old Mar 2, 2012 | 09:35 PM
WhiteChocolateTypeS
Have tried everything...thanks so some much needed troubleshooting with aznboi2424 we found the answer, if you are having this issue is likely due to the failure of one or all of the following sensors:
Lateral Acceleration Sensor
Yaw Rate Sensor
Steering Angle Sensor
Nothing major, but VSA is disabled until you either track down the problem or replaced all the sensors in one shot.
ECU Reset will NOT be effective in deleting these codes, nor will getting them removed by a mechanic.
Old Mar 2, 2012 | 10:56 PM
aznboi2424's Avatar
Hopefully it will be an easy fix when you come back.
Jamus22
Jun 11, 2023 10:08 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
