Need help on Toyo tire pressures
I just got T1-S Proxes, they are same as stock 215-50-17. The sidewall says max pressure with full load is 44 psi. Well when i checked them today, pressure was set at 44 all around. The shop i got them at, Motorsports Dynamics is a well respected local speed shop and i'd like to believe they know what they are doing. But i would like to get feedback on what you think the best all around pressure is. If i recall someone else had theirs at 39,whats the advantage of running that high ? Thanks.
Originally posted by Red Rider:
<STRONG>I just got T1-S Proxes, they are same as stock 215-50-17. The sidewall says max pressure with full load is 44 psi. Well when i checked them today, pressure was set at 44 all around. The shop i got them at, Motorsports Dynamics is a well respected local speed shop and i'd like to believe they know what they are doing. But i would like to get feedback on what you think the best all around pressure is. If i recall someone else had theirs at 39,whats the advantage of running that high ? Thanks.</STRONG>
There is a difference...
You got the 215/50-17s which are NOT XL rated (They do not have the reinforced casing. The toyo page is kind of screwed-up -- it should show 50 (or 51) max PSI for tires with the "*" (See my sig).
The 215/50ZR17-91Y is only rated for 44 lbs max. I would watch your tire pressure. On your tire the absolute max pressure is 44PSI -- and no more!! On my 235/45s with the reinforced casing, the max pressure is 50/51 PSI!
I am the one running 39PSI (racing pressure), but the tire will take 50 lbs, and the footprint is just right.
mugen_kid
Nov 13, 2015 10:38 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
HeloDown
Sep 8, 2015 06:51 PM
