Need help resolving a slight plastic rattle.
Old Jan 29, 2004 | 02:05 PM
Gabo3k's Avatar
I live in Southern California and most of the year it's sunny and my car is rattle free. However, when the cold weather comes around, I get a light rattle right above both driver and passanger windows - near the plastic part before the headliner starts.
I know it's just a matter of applying some sort of insulator to keep the two plastic parts from rubbing, I just don't know what to use.
Any suggestions, anyone?
I can't wait to have my car rattle free again.
Old Jan 30, 2004 | 10:30 AM
Gabo3k's Avatar
Come on guys, someone must have an idea!
Old Jan 30, 2004 | 10:36 AM
gto2050's Avatar
Someday pigs WILL fly!
Cold weather? In Southern California? What did it get down to, 50? Yikes it was 16 this morning! With cold weather metal and plastic shrink and they rattle.
ChadT's Avatar
Spectacular Aroma About
Make sure you have the right spot. It can be difficult to tell where a sound is coming from inside a car. I thought I had a rattle at the door but it turned out to be the fuse box cover. If you push on the lower dash and the rattle stops it's probably the fuse box lid and you can stuff a piece of foam behind it. If it is actually the door you can try some silicone spray on the door seal.
Old Jan 30, 2004 | 10:37 AM
Python2121's Avatar
The hair says it all
my car rattles like thats its job when it gets under 10 degrees over here in ny
Old Jan 30, 2004 | 10:46 AM
blader's Avatar
Audi S4 driver
Old Jan 30, 2004 | 01:34 PM
Gabo3k's Avatar
Silicone spray sounds like a good solution. I will try this tonight.
Thanks for the replies guys.
Old Jan 30, 2004 | 01:44 PM
dgracer's Avatar
I'm not too far from you myself at it gets down to the mid 30's where I am. Mine has the classic rear deck rattle and I've stuffed several roles of felt between the deck and rear glass but it still does it now and then. The pass seat also rattles when it is 'cold'. Havent found that one yet. Good luck. Let us know if you find it.
hashbrown
Feb 18, 2022 11:20 AM
mlody
Dec 4, 2019 02:11 PM
emailnatec
29
Sep 28, 2018 04:27 PM
dainmezron
Oct 16, 2015 06:56 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
