need help owners of comptech springs!!!
Old 03-07-2001 | 10:31 PM
typeR's Avatar
i need to know a percise measurement of the drop from the springs on a flat surface any fixed points to the grond or hub or anything i can reproduce what im thinking is h&R oe front comptech rear if comps are exactally 1.0 drop rear but ineed to know front and rear as many different people the better but not if you have heavy stero equip in trunk thanks for the help
'01 3.2 CL typeS
satin silver metalic
Llumar platinum plus
tint 20% all around
'98 ACCORD V-6 sedan
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Old 03-07-2001 | 11:09 PM
typeR's Avatar
oh ya stock tire and wheel only please
'01 3.2 CL typeS
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Old 03-08-2001 | 01:50 AM
typeR's Avatar
'01 3.2 CL typeS
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Old 03-09-2001 | 12:42 AM
Jens H.'s Avatar
retired
TypeR I amsure within the next few days I am lowering another CL/S I'll take the measurements for you.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
Old 03-09-2001 | 12:49 AM
typeR's Avatar
thanks jens...with stock rubber it looks like ive found my solution im gonna get the comptech springs but add the koni shocks to raise the front the full .50 an expensive solution but i think the right one .
'01 3.2 CL typeS
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Old 03-09-2001 | 01:29 PM
GoldTypeS_RENAMED's Avatar
typeR -
My drop was 1.25 inches in the front, 1.0 inches in the rear. I am riding on stock rubber and wheels.
Old 03-09-2001 | 02:18 PM
typeR's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GoldTypeS:
typeR -
</font>
so far everything ive been seeing is 1.5 front but what i was looking for was your car measured from a fixed repeatable point to the ground not that i dont appreciate the response i certainly DO let me know
'01 3.2 CL typeS
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Old 03-09-2001 | 03:17 PM
<font face="Verdana, Arial" size="2">Originally posted by typeR:
</font>
Who's been saying 1.5??? Prior to getting springs I had read only 1.25 front and when I took my after install measurement that's exactly what it turned out to be. 1.25 front and 1.0 back.
Anyways, here are some more measurements.
- From just behind the front wheel, I measured from the lowest part of the rocker panel and it's 7.0 inches to the ground.
- From just in front of the rear wheel, I measured from the lowest part of the rocker panel and it's 8.0 inches to the ground.
- From the point in the front bumper to the ground is 8.5 inches.
I used a plastic ruler (I'm at work - its all I had) so the measurements are probably not exact. But they should be within 1/4 inch. Hope that helps!
2001 Acura 3.2CL Type S
Comptech Springs
Comptech Sway Bars
Comptech Headers
PIAA 19169
Old 03-09-2001 | 04:19 PM
typeR's Avatar
</font>
just in front of my front wheel is 9.0 and at that point in the bumper 10.5 and back wheel is 9.0 and this is concistant with the others that have sent me measurements looks like 1.5 front 1.0 rear and it makes perfect sense...these springs were either developed for the accord or tl i suspect accord our car is over or about 100lbs heavier up front than tl and approx 26lbs lighter than the tl in the rear ive done the math so whats happening is under the additional load up front our car is droping .25 inches but because of the lighter rear its droping .25 less than spec the comps i think were designed to give a 1.25 f/r but because of weight diff it doesnt work out that way so koni's for me to bring the front back up almost .50 but for you guys that wouldnt mind lower you could do the same thing but bring the back down the .50 either way flat is attainable:d
'01 3.2 CL typeS
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Usmcgrunt47
10-13-2023 09:35 PM
emailnatec
29
09-28-2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
07-11-2016 11:07 AM
Quick Reply: need help owners of comptech springs!!!
