Need help identifying my rotors/calipers
Old 12-23-2014, 01:37 PM
tr59210's Avatar
Hi everyone,
A while back I tried replacing my rotors, but the ones I got for it didn't fit.
I do have the part number on the caliper which is 17CL15VN
Is this the OEM caliper that came with it? Does anyone know which are the original? I think the previous owner must have switched out the rotors/calipers for an aftermarket brand...
thanks
Old 12-23-2014, 01:41 PM
Received 16,260 Likes on 11,971 Posts
a very simple google search yielded a result.
that caliper is from the Acura Legend.
Old 12-23-2014, 01:43 PM
also, from a very simple google search tells me that the bracket used on your car will determine which rotor you will need.
Originally Posted by google search
The '91-'95 Legend, '96-'98 3.2TL and '96-'04 3.5RL all use those calipers. It mount them on the back side of the knuckle. Therefor the bleeder is on the opposite side. It is completely fine to swap them around to orient the bleeders like you want them.
The 23T bracket will be problematic with the rotors you want to use, though. The "23" in 23T indicates that it should be used on a 23mm rotor. For a 25mm thick rotor you'll need a 25T bracket. I've posted in a few threads extensive lists of where the parts can be sourced.
tr59210 (12-23-2014)
Old 12-23-2014, 01:47 PM
tr59210's Avatar
Ah, thank you so much. I don't know why they were switched out, however, I'll try replacing the rotors with rotors that match the current setup.
Old 12-23-2014, 01:52 PM
from googling; it seems the Legend Calipers provide better stopping.
you'll need to look at the bracket on your car to see if it's 23mm or 25mm.
I'm most positive that it's 23mm in thickness.
Old 12-23-2014, 01:54 PM
tr59210's Avatar
Yeah last time I tried replacing them with OEM, the rotors were too thick. So I'm guessing it's 23mm. Now I just need to find them...
Old 12-23-2014, 09:16 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Why did they swap out the brackets? The legend calipers (2 piston) fit the CL/TL brackets and no rotor change is necessary (meaning you can use the TL/CL rotors with it.
08-15-2019 12:58 PM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
Nizmosis
10-13-2015 02:25 PM
Scottyknows007
09-21-2015 01:03 PM
mv01
09-15-2015 10:36 AM
Quick Reply: Need help identifying my rotors/calipers
