need help with headlight situation
Old Mar 17, 2016 | 05:05 PM
orion2x10's Avatar
i might be buying an acura cl type s an the person im getting it from says that one of the headlights keeps blowing and tripping the fuse(im under the impression there are separate fuses for the different headlights. can anyone help me with this before i buy the car an have to sink a bunch of money into it?
any help woul be greatly appreciated. thanks in advance
Old Mar 17, 2016 | 07:32 PM
orion2x10's Avatar
has anyone had this problem if so i could really use some advice
Old Mar 17, 2016 | 08:46 PM
coopcoop30's Avatar
I would check the ballast or look for a short somewhere. If there are separate fuses for the headlights, and I'm not sure if there are or not.......then it's a short or ballast issue. If you can fix that yourself then you can do it for a couple hundred bucks.
Old Mar 17, 2016 | 08:58 PM
orion2x10's Avatar
i read somewhere else it could be the ballast or ignitor so thanks for the info maybe someone who has had the same problem will chime in
Old Mar 17, 2016 | 09:00 PM
orion2x10's Avatar
do you know of a place i can get an aftermarket ballast that will bolt right up for cheap
Old Mar 17, 2016 | 10:28 PM
orion2x10's Avatar
bump!
Old Mar 18, 2016 | 02:35 AM
01acls's Avatar
Originally Posted by orion2x10
bump!
Simple, tell the guy to fix the car with oem parts or you won't buy the car.
Old Mar 18, 2016 | 07:49 AM
coopcoop30's Avatar
You can find them all over eBay for about $100. But if I were you, and I purchased the car, I would purchase 2 new ballast and bulbs and be done with it. Try theretrofitsource.com. Also it's not just a "bolt up" replacement. You have to take the bumper off as well as take the headlight off. Not difficult to do though.
Old Mar 18, 2016 | 08:51 AM
orion2x10's Avatar
does this sound like it could be the problem to you guys hes selling me the car cheap
Old Mar 18, 2016 | 03:50 PM
orion2x10's Avatar
i would really like to know if anyone knows that this is the problem
Old Mar 18, 2016 | 03:54 PM
coopcoop30's Avatar
I don't think you've ever told us the price of the car. I would be confident that I could fix it regardless of the problem but I can't speak for you.
Old Mar 18, 2016 | 04:03 PM
orion2x10's Avatar
the car is 700 but if the ballast and ignitor dont fix the headlight problem im skeptical about purchasing it cause it could cost me more money than i have
Old Mar 18, 2016 | 04:06 PM
coopcoop30's Avatar
I can understand that. The problem is that this is a used car. You take a risk like this when you buy used. I would assume for $700 the car has to be pretty run down. I guess if you have the mechanical know how then the choice is yours. If you don't have the knowledge or money to fix it yourself then the choice has already been made.
Old Mar 18, 2016 | 04:12 PM
I think i'd worry more about the dying transmission than the ballast..
Old Mar 18, 2016 | 04:13 PM
orion2x10's Avatar
i can do mechanical work i just dont know about electrical systems and from what i unerstand it just needs the headlight fixed a paintjob and the driverside winow motor replaced and keep in mind im driving a 91 ford ranger that i paid 500 for 3 years ago
Old Mar 18, 2016 | 04:48 PM
coopcoop30's Avatar
There's plenty of information on this website that can help you. I'm not telling you to purchase it though. The decision is yours. I would say ballast or short somewhere.
Old Mar 18, 2016 | 04:53 PM
orion2x10's Avatar
thank you for your help
Old Mar 18, 2016 | 04:58 PM
orion2x10's Avatar
how would i tell if the transmission is going out on the test drive
JJones91
Oct 17, 2016 06:52 PM
MikeekiM
Apr 18, 2016 01:07 AM
bentleyvtech
Mar 20, 2016 08:23 AM
Mr. Showtime
Mar 18, 2016 10:36 PM
74novaSS
1G CL Problems & Fixes
Feb 8, 2016 06:24 PM
