need help!
Old Nov 27, 2006 | 11:13 PM
blueCL's Avatar
Need For 6 Speed
need help!
i just put in my k and n filter and it's making a humming sound...is this normal?? it's just a filter not a whole short ram or cold air.
Old Nov 28, 2006 | 12:06 AM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Is the airbox cover secured completely? If the airbox is still open it will most deffinately hum. I had a similar situation with my air box when I installed my K&N. Apparently the dealer someone managed to break both of the clips on the base of the airbox where the tabs of the top slid into, so It made a slight humming sound. My solution was a couple of long zip ties to hold down the top of the air box, which really was a pita to put in because I took apart the whole thing to get the zip ties underneath.
Old Nov 28, 2006 | 12:11 AM
blueCL's Avatar
Need For 6 Speed
well do i need to zip tie it?? i mean i sorta like the hum sound as long as it's not bad for my car.
Old Nov 28, 2006 | 08:29 AM
fuzzy02CLS's Avatar
Did you simply change the filter to the K&N? Did you mess with the box at all or the resonator?
Cause I was messing with mine a few weeks ago. I've been running without the resonator for over a year but left the little rubber seal that went around the airbox hole.
Well I tried removing this & got this LOUD whine from the airbox at idle. I put that rubber piece back in & it was gone.
It is supposed to hum a little bit though.
Old Nov 28, 2006 | 01:48 PM
blueCL's Avatar
Need For 6 Speed
yeah just replaced the filter to K&N and the humming is not that loud but i like it...so it should be fine right? i didn't mess with the box at all.
Old Nov 28, 2006 | 02:00 PM
Lord Helmet's Avatar
I'm here in spirit...
Sounds normal to me.
