Need Amp info, please help!
Old Jul 14, 2005 | 04:04 PM
Lord Helmet's Avatar
I'm here in spirit...
mods: Sorry to post here but I figured I'd get a better response this way.
I'm thinking of replacing the stock Bose amp with an aftermarket one. If I understand correctly, the stock unit is only like 4x25w?? I have been doing some searching on here and I'm getting mixed info. I'd like to use the output the stock Bose amp as my pre-amp signal w/LOC or using speaker level outputs into the aftermarket. Will this perform? Has anyone done a replacement like this successfuly? If so, how did it sound? I hear the Stock Bose speakers are 1ohm and most aftermarket amps put out 2 or 4ohms. What problems might this cause? Won't the single ohms change the power output of my amp? honestly, I don't even know if it's possible to do this but if someone has done this please tell me! Any expert advice on this I would appreciate!
-Chris
Old Jul 14, 2005 | 04:40 PM
civicking's Avatar
if they are 1ohm speakers it will over heat the amp, too much current will go through the amp, and i can fry it.
Old Jul 14, 2005 | 05:20 PM
AcuraTL's Avatar
OG
If you are going to replace the amplifier, you might as well replace the speakers also because unless you are getting a high-end competition high current amplifier, it will fry your amp because of the low impediance of the stock speakers.
Old Jul 14, 2005 | 05:40 PM
kevin79925's Avatar
i did this but i also replace my stock speakers. and it sounds awsome
old pix i have a jl audio W7 in there now tho
Old Jul 14, 2005 | 08:54 PM
^^^ Did you replace the stock speakers at the same time as the amp?
Old Jul 14, 2005 | 10:46 PM
Shawn S's Avatar
Sorry I have to LOCK it, but that's the rules.
You know where to post this type of question.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
