Navi Kaput
Navi Kaput
Just saw my navigation system die. Now I just get wavy color lines on the display. Probably means a trip back to the dealer, but just thought I would see if anyone else has had a similar problem and if there was anything that I could look for myself. Thanks
<font face="Verdana, Arial" size="2">Originally posted by berkesnd1:
</font>
</font>
If you are glutton for punishment:
You need to start up the car in Park. Then hit the OK message on the Nav screen -- this may be impossible for you to do (if the screen is too messed up, or can't approximate where the OK would be on the screen).
You didn't say if the unit dies before or after you hit the "OK -- I understand that I can't be a moron and stare at the NAVI while driving.." screen.
If you can hit the OK button screen, then...
Press and hold down the following buttons in the order shown:
MENU
MAP
CANCEL
Hold buttons and wait from 5 - 20 seconds.
If the diags is working you will get a screen with submenus. One is a system diagnostic menu -- but it does need a working display.
The Helms manual fully documents the operation of the diagnostics.
If your LCD panel or video driver is too messed-up, there won't be a way to diagnose the unit with the brain damaged screen. If this is the case, sorry for wasting your time.
Good luck.
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 10 coats of Zaino magic
A-CL Official BMW Troll
Check the plug behind the dvd unit in the trunk. The plug may be loose.
2001 BLK/ebony CL-S w/NAV (waiting for delivery)
I had the same problem. I called the dealership and they had already heard about it. I did not even need to bring it in. They said it was some kind of grounding problem and would replace the screen.
I had the NAVI system restart 3 times since I owned the car. It goes to the world screen and restarts, one time it just froze while giving directions, I turned the car off and started it again and it was fine. Has anyone else had this problem???
Silver S
Black Xephyr Intake
Valentine 1 (Hard wired)
Silver S
Black Xephyr Intake
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
