My Power steering feels weird
Normally my steering wheel feels lighter than my mom's 325i but now it's kinda stiff which doesn't feel right. I checked the Power Steering Fluid and the level is at lower which after reading the manual it said that this is bad and then I went to Pepboys to get ready and buy the fluid and checked again before I went in and now the level is in between upper and lower. Do I need more Power Steering Fluid and is it suppose to fluctuate like that? Plus when I turn my steering wheel left and right you can hear squeaky noises from the outside.
How cold was it ??
My CLS's power streering gets real tight when it's cold out (below freezing). The whole car feels very "heavy and tight" when it's below 10 degrees. Sorta like how I feel on a cold monday morning (want to stay in bed).
Typically, you have a choice between checking the fluid warm or cold, and there will be corresponding "Hot" and "Cold" levels (marks). I'm not familiar with the "correct" fluid level on the CL (I've never checked mine :0 ), but the owners manual should cover this.
edit: Squealing could be a loose or worn belt too.
Meat stick
Originally Posted by GreenMonster
How cold was it ??
also, if the fluid has broken down, it may need to be replaced....also, the sqealing may indicate a failing PS pump....so change the fluid ASAP to try and save the pump
Service said that the rack was leaking from both ends, ordered a new PS rack, replaced it under warranty, been fine since.
They even offered to reimburse me for the bottle of fluid... Continental Acura of Dupage in Naperville IL is a great dealership.
Good luck to you.
Hey,
I just had both lower ball joints replaced under warranty (03 6sp with 35kmiles). I didn't notice any tightness but there was a squeak when turning the wheel that you could really hear if you were in a parking garage.
Good luck figuring out what it is.
Blackdog
Blackdog
blah i guess i have to take it to the dealer again once more. After counting how many times i took my car to the dealer it's been exactly 16 times. Most for the same problems.
mike from annapolis
05-07-2017 08:21 PM
