My car only blows cold air..... help!
My Work is Done Here
1 Post
So my heat won't work, no matter what temp I set the air at, it seems that the car only wants to blow cold air. Even if it's warm outside, the car still blows cold air.
The display doesn't say that the AC is on.
It's not the temp sensor in the car because it still does it when I take the fan off auto.
I'd like to keep from having to go to the dealer, so anyone got any tips? experience with this problem?
thermostat is mechanical and there's no way the PCM would light up CEL.
has to be verified :
- thermostat
- coolant level (air free system)
- heater valve (right in front of the firewall a little on the pass side from center), look if the cable is working properly from cold to hot on the HVAC, check if valve is spinning or is it only the top portion with the cable (happened to me once on a MDX)
- thermostat
1 Post
Okay, it's not the thermostat, the car heats up to normal operating temp range, and the hoses feel hot as normal.
Coolant level is fine, about a third of the way above the minimum line when cool.
TypeSZero, can you explain a little more what I'm looking for on the heater valve to see if it's working properly? Do I need to have someone inside adjusting the heat/ac while I do this?
- thermostat
- thermostat
how handsome I am
Thanks![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
1 Post
Originally Posted by honda_inspire99
The thermostat has nothing to with if you car blows hot air or not...If the thermostat was stuck open then you car would run hot all the time
![Huh](https://acurazine.com/forums/images/smilies/huh.gif)
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
again as per link above:
Weak thermostats can open too soon Ray A.
Symptoms of weak, open thermostat: engine temperature does not get up to normal; heater puts out only warm or cool air; engine may not perform up to normal standards; hoses may be cooler than normal (touch carefully).
note sig
note sig
