My '03 CL-S MT stronger in cooler weather...why ???
I know that engines really like cooler ambient temps but I have noticed that since we've (NYC) had this strecth of 80 degrees...then back down to 40/50's from day to day that the engine feels much stronger in all gears/ranges when it's cooler. A/C not being used yet) is this related to the "winter gas" that is still being sold at the pump???
Happy CL-S Pilot
Using this Calc: http://wahiduddin.net/calc/calc_hp_abs.htm
Temp 40F, Absolute Pressure: 30.50, 25% Relative Humidity ==> Correction Factor = 0.914. Engine makes , 109.5% of SAE normal conditions
Temp 90F, Absolute Pressure: 29.00, 100% Relative Humidity ==> Correction Factor = 1.086. Engine makes 92.1% of SAE normal conditions
ex 6 Speed owner :(
Yeah, temperature is a big deal but not as much as elevation! Take a look at this graph I made to see what the difference would be from sea-level here in L.A. to the South Rim of the Grand Canyon (7100ft.):
Cost Drivers!!!!
Originally posted by darrinb
would this help out w/ the hotter temps??
NISMO pwnz j00!
Originally posted by Nashua_Night_Hawk
no weather can increase or decrease HP by 7-10%!! It is like having 180 WHP at one day and the next is like 220 WHP.
.65 x 14.7 =9.55 PSI
.82 x 14.7 =12.05 PSI
VOTE OUT THE BUSH REGIME
I can tell you for sure that my TL runs like shit when the whether is 115 degrees here in the summer. The 3.2 liter engine is very happy between 32 and 60 degrees. You will notice this expecially in the morning if you stomp the gas within the first 5 minutes of driving. It has mad torque and pulls like crazy!@!
Cost Drivers!!!!
how much does it cost??
$90 for the unit plus install. They say it can be done at home. See the next page in Scalbert's post.
Retired. Not available.
Best days for CLS when it is cold (anywhere below 40-50F) AND clear with High Pressure AND low Relative Humidity or Low Dew Point.
Originally posted by Zapata
$90 for the unit plus install. They say it can be done at home since it's just swap in the water pump.
In the below pic you can see the coolant hose to the very left with the spring clamp on it. This is attached to the T-Stat housing and you can just about see the lower bolt:
T-Stat Housing
Cost Drivers!!!!
Originally posted by scalbert
Not the water pump, the T-Stat housing and fan switch are located just below the TB.
T-Stat Housing
T-Stat Housing
Really? Huh....well i guess it makes the install a little easier then?
Cost Drivers!!!!
Significantly easier and somethin someone with a 12mm socket and an adjustable wrench can have done in twenty minutes (less the clean up).
Well i'll be a monkey's uncle. Thanks
hey thanks for the feedback ....I knew it wasn't just my imagination!!! Yesterday and Wednesday and thursday here in NYC we've been in the fifties and the car is super strong. Does the CT Icebox help with the warmer weather performance??
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
RSpyder
09-30-2015 12:46 AM
