moisture in headlamps. help!!
Old Dec 23, 2003 | 12:23 PM
JPPHARMD's Avatar
i have a problem. I have moisutre in my passenger side headlamp. I still have the factory warrenty (4yr/50k) left. would this be covered by the warrenty. i called 2 dealers, one said yes and the other said they will have to check it. any ideas? the dealer who said yes is farrrrr away. any help will be appreciated. thanks.
Old Dec 23, 2003 | 12:54 PM
Red-CL's Avatar
Doin' da crack shuffle
They will have to cover it. A few people had them replaced.
Old Dec 23, 2003 | 02:04 PM
acur8ly's Avatar
Yep they will cover it, I had them replaced 3 times on my Cls
Old Dec 23, 2003 | 04:35 PM
hons CLS's Avatar
Got CL-S?
They should cover it. They changed mine, but still fogging up.
Old Dec 23, 2003 | 06:32 PM
dallison's Avatar
registered pw
mine have f'in fingerprints inside em
Old Dec 23, 2003 | 10:08 PM
Chopsie's Avatar
Beware of leakage
I have this problem with my new ones. Dealer just replaced mine due to having as film looking stuff on the inside of the housing. My old ones did not fog, now when I wash they fog.
Old Dec 23, 2003 | 10:09 PM
Chopsie's Avatar
Beware of leakage
For real, mine too!! Now that you mentioned it, thats exactly what I see in mine when they do fog.
Old Dec 23, 2003 | 11:54 PM
sgmotoring's Avatar
Bleed Honda Blue
If the lens have no visual damage Acura will replace them.
Old Dec 24, 2003 | 12:12 AM
randomwalk101's Avatar
yep....if it is not cracked (ei accidence etc), then it should be underwarranty. The reason they said "gotta look" I guess because they wanted to see if it is damaged (physically) or not.
BTW, by looking at your nick, are you a certified (rph) dope-dealer or still in the making?
Old Apr 2, 2007 | 07:27 PM
noodle's Avatar
03 : cls6 - ABP
ok, so i'm bringing this back from the dead. hi, i'm new. just got the one of the best deals ever. 03 cls 6 aegean blue-100k mi. < that doesn't bother me. i'm loving this car 2 weeks in. posting because unfortunately my car is definitely not under any warranty. any suggestions on removing and somewhat sealing this headlamp housing to keep moisture out ? thanks a lot for any infomation.
Old Apr 2, 2007 | 07:38 PM
nbennettksu's Avatar
i heart latin chicks
1. take your bumper off 2. disconnect all the bulbs from the headlight, you can take the bulbs out if you want (but I didnt since they get way hotter than the oven). 3. remove the headlight. 4. pre-heat your oven to 350ºF 4. get a cookie sheet and dampen a towl, then cover the cookiesheet with the towel 5. Place the whole headlight on the cookie sheet. 6. put the cookiesheet/towel/healight into the oven thats cooking at 350ºF for 15 mins.
when the 15 mins are up, take out the headlight and get a flathead screwdriver (one that you dont care to ruin) and pry the headlight apart. The glue that headlight makers use one that expands when heated. once you have the headlight apart, make sure there is the grey sticky adhesive, aka glue, is distributed evenly all over the edges (which yours is probably not, there is a slight gap somewhere). Now if you want, you can remove that yellow reflector!!! or clean off any fingerprints!!! Once you got it all even throughout the edges, push it back together and hook those clamps all along the edges. Then stick that sucker back in the oven for 15 more mins. Take it out, let it cool for a good 30 mins and you're good to go, with a new cleared out lense and all that wont get foggy anymore! I've done this 13 different cars including mine and i've never had another fog up on me. Hope that helped
Old Apr 2, 2007 | 07:44 PM
noodle's Avatar
03 : cls6 - ABP
ahahahaa - thank you. it certainly helped. i now have all the information i need to take care of that. if and when i ever decide to take those 6-7 steps. wow. i'd rather drive 15 hrs. to atlanta and sit and wait an hour or two for you to take care of it. hah. thanks though for the reply. + props to you doing that 13 times. keep up the good work
Old Apr 3, 2007 | 07:46 PM
werd. if you got any more questions, just pm me
Old Sep 14, 2007 | 01:49 PM
CLmadness's Avatar
5th Gear
I gotta try this...
Hopefully you guys still see replies to this old thread. I just bought a 2001 cl and it's a pretty cool car I just happened to stumble upon at a used car lot. Now that I see so many enthusiasts, I'm getting into it even more. My headlights have some moisture inside and are also discolored slightly (foggy, cloudy, etc.). The steps listed in this thread seem pretty simple, but no mention of using new epoxy to seal it back up? Just curious about that. Also, is there any way to just replace the plastic portion (lens) while I have it dissasembled rather than trying out the 2000-3000 grit sanding method I also saw people mentioning that looks like an all day project? Thanks in advance for any feedback.
Old Dec 29, 2007 | 09:08 AM
djagh's Avatar
Hey that worked great!! I just put in 2 new ballasts and used the method above to clean out the lenses, nice!
Question....how do I aim the headlights? One seems to be pointing correctly, the other points to the sky... Any ideas?
Feb 25, 2020 09:57 AM
BigJilm
Sep 21, 2015 08:32 PM
max4swag
Sep 14, 2015 07:55 AM
bebop.fey
May 19, 2006 10:29 PM
