MM-I and MM-II Secret Revealed!
Old Aug 13, 2003 | 07:42 PM
  #41
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
black2k3,
See page 2 of this thread for pics.
Old Aug 13, 2003 | 07:46 PM
  #42
SiGGy's Avatar
Moderator Alumnus
Originally posted by Astroboy
ok...guys, this is great stuff...BUT....
I can only assume Steve's absence means that Jennifer has given birth!
so, I'd like to say CONGRATS STEVE I know it's been an awfully long process, but it's finally come full circle, congrats on the success
ya... hopefully there isn't any complications!
he's going to have his hands full for awhile
Old Aug 14, 2003 | 07:07 AM
  #43
scalbert's Avatar
Just haven't followed this thread...
But yes, hands are full right now but it is fun.
As for blocking the EGR, it can easily be done. There are five pins on the EGR connector; the bottom two are for the duty cycle control of the valve.
The other three are 5VDC VCC, Sensor Ground and Lift Sensor Signal.
You can disconnect the connector on the EGR valve and use a resistor across the control terminals to simulate the valve, 1k Ohm @ 1 Watt should work fine. For the sensor feedback simulation, just use a 100k Ohm potentiometer as a voltage divider to supply 1.2 - 1.5 VDC back to the ECU.
This should work just fine provided what Doug has alluded to; the ECU will watch for a transition in the O2 voltage when the EGR valve is commanded open, is not complete. IMO, Honda hasn't been the most sophisticated in the ECU controls and although the math might be in there to check for this; it probably isn't that sensitive.
But regardless, the relevance of this is questionable. Eliminating the EGR won't really provide gains as it is closed during WOT anyway.
I was looking into this since the new manifold/IC would require cutting passages or eliminating the EGR system. But in the end I do think I will add it in for emissions compliance (I guess my environmentally conscious side got to me. ).
Old Aug 14, 2003 | 07:44 AM
  #44
Happy CL-S Pilot
I am considering this mod now. I noted the EGR is active at idle and the mod is working at idle, however, any reference of the work of EGR valve that state the EGR is close at WOT?
Also, I am sure we will see some MPG drop with this mod.
Finally, if there is gains and the CLS feels lighter at partial throttle, why not? It is like a tiny SC!
Old Aug 14, 2003 | 08:12 AM
  #45
scalbert's Avatar
A duty cycle monitor on the control signal would tell you the state at various throttle positions. Also, just monitoring the Lift Position sensor output signal would tell you the same.
Old Aug 14, 2003 | 12:15 PM
  #46
typeR's Avatar
speaking to MMII how might i clamp the ECT to a state that were just starting to warm up ...as if the engine coolant level had achieved 2 clicks of temp increase on the cars coolant temp gauge ???
Old Aug 14, 2003 | 12:49 PM
  #47
scalbert's Avatar
I don't quite follow; you want the ECU to think the engine is warmer than it really is??
Old Aug 14, 2003 | 07:41 PM
  #48
typeR's Avatar
colder...i want to only allow signal through of full cold up until the first 2 clicks on the temp gauge 120-140*
Old Aug 17, 2003 | 06:00 AM
  #49
Juker008's Avatar
TRELOS
Why .
Juker008
Old Aug 17, 2003 | 06:49 AM
  #50
typeR's Avatar
Originally posted by Juker008
Why .
Juker008
because timing is very advanced then
Old Aug 17, 2003 | 07:08 AM
  #51
Happy CL-S Pilot
if the engine is cold, the ECU will pull back on timing, you will lose some 20 WHP at WOT!
Old Aug 17, 2003 | 07:22 AM
  #52
typeR's Avatar
not cold ...warm
Old Aug 17, 2003 | 07:30 AM
  #53
Happy CL-S Pilot
type-r... in open loop mode ( when the engine in partial open throttle ) warning up the engine, you can not reach the max performace of the engine.
Old Aug 17, 2003 | 08:03 AM
  #54
typeR's Avatar
you're not hearing me... when i first start my car ,about 1-2 minutes later the car is just starting to warm ,up maybe 2 clicks on the temp gauge... in the heat from a rolling start i get on it...on the SS 1-2 it spins the tires hard with alot of torque steer, and then if i time it just right i bark 3rd ,this is not because of the temp of tires, this is to me a state of timing being advanced, due to one of 2 things,maybe both... cooler head temps ,low ECT value, scalbert has mentioned several times how much influence the ECT has on timing...i think it's both with an emphasis on the ECT ...i want to clamp off the info of a hotter ECT value to the ECU, allowing it only to see, say 140 or colder .i'd be willing to expriment, maybe 140 is too cold? try 150 then 160 with 160 being the max
Old Aug 17, 2003 | 08:43 AM
  #55
Happy CL-S Pilot
OKay, I understand. You are in Blazing Florida, and your engine will heat soaked quickly.
It could a better choice to invest in low temp Thermo to keep the engine a bit cooler by 2 clicks all the time.
Nahsua.
Old Aug 17, 2003 | 09:24 AM
  #56
scalbert's Avatar
The engine will go into closed loop as low as 100 - 120 F so that is not a problem. The engine also runs more timing with the lower ECT value, this is proven but IMO, limited. By going down to 140 degree you do not get the same linear timing increase as from 200 to 180 F.
However, if you try and trick the car into thinking it is colder than it really is you WILL suffer cold starting problem.
To lower the percieved temperature play with some resistors in series to get the desired value.
But why not just run a lower temp T-Stat??
Old Aug 17, 2003 | 09:31 AM
  #57
typeR's Avatar
well already have the mugen ...
Old Aug 17, 2003 | 01:12 PM
  #58
scalbert's Avatar
Then you won't gain anything further. The reason you are feeling more power when cold is because the air entering the engine is cooler. Tricking the ECU won't really gain anything beyond what the T-Stat is giving you.
Also, consistant values below about 170 F would trigger a DTC.
Old Aug 18, 2003 | 11:32 AM
  #59
Juker008's Avatar
TRELOS
About the T-Stat. Since I am the Southern most out of all of us couldn't I get away with just removing the T-Stat? Its not like the CLS is going to experence freezing weather anytime soon, not till teh next Ice-Age.
Juker008
Old Aug 18, 2003 | 11:36 AM
  #60
Happy CL-S Pilot
If there is no freezing... empty the radiator and replace it with pure H20 and some Redline:
http://drs.yahoo.com/S=2766679/K=red...neoil/wwti.htm
Old Aug 18, 2003 | 11:46 AM
  #61
scalbert's Avatar
You will, without a doubt, set a code. I drilled out the stock stat and set a code rather easily as it takes too long to warm up.
Old Aug 18, 2003 | 12:00 PM
  #62
typeR's Avatar
i'd say you''ll crack your heater core if you do that
Old Aug 19, 2003 | 09:49 AM
  #63
Juker008's Avatar
TRELOS
Nash,
U know I would definatly go with pure H2O and watter wetter, but there is no lube in the water system. Thats why u would need coolant, it is the water systems lube. I would think that if only water were used the water pump would go out in a month.
Juker008
Old Aug 19, 2003 | 09:52 AM
  #64
Happy CL-S Pilot
Ah... Realine recommends a minumun of 20% of anti-freeze.
Old Aug 19, 2003 | 10:37 AM
  #65
Juker008's Avatar
TRELOS
Ahhh ok then, that sounds more logical.
Juker008
Feb 25, 2020 09:57 AM
thegipper
Oct 21, 2015 07:19 AM
rockyboy
Sep 21, 2015 10:47 AM
Sep 21, 2015 08:44 AM
AZuser
Sep 17, 2015 10:15 AM
